From TW200 to Yamaha WR250R
Page 1 of 6 123 ... LastLast
Results 1 to 10 of 52
Like Tree62Likes
Thread: From TW200 to Yamaha WR250R
    Senior Member Prime's Avatar
    Feb 2013
    Hammonton, New Jersey
    145
    As promised, this will be my WR250R thread.
    I spent a considerable amount of time researching bikes that would suit my mission better than the TW200. However, it's hard to find a direct comparison of the TW and WR, as most people are comparing the WR with a KLX or CRF-L or KTM or whatever. So, I thought I'd provide my thoughts on going from TW to WR here on the forum. Hopefully this doesn't stray too far off topic for a TW forum. This will not be TW bashing, I love TWs.
    Define your Terms:
    I say things like "my mission" and better suited for me versus MY particular TW. What does that mean exactly? Your mission may be totally different. A little background will help.
    My TW was a 1991 model. So first gen, drum brakes, kickstart. Mostly stock except for proper jetting and Shinko 244 front tire and fresh TW rear. Stock gearing, no suspension mods. Pro taper high ATV bars and wide pegs for comfort.
    My WRR is a 2013 model. Totally stock, except for more aggressive dirt tires (though still DOT legal) Kenda Trak Masters.
    My mission is relatively simple. The bike had to be street legal, from the factory. My state does not allow plating of dirtbikes at this time. I have a limited budget, so I was trying to stay with a Japanese bike. The KTMs are great, but too expensive. As for my riding, this bike would be 90% offroad use. I have no interest in touring on it at this point, I have street bikes for that. The road use is limited to what it takes to get me to the trails. Thankfully I have millions of state forest acres within a 15-30 minute ride from my front door. So, I wanted a bike that could handle my local terrain (sandy, whooped out trails, fire roads, single track).
    jtomelliott49 likes this.
    -Travis
    1989 TW200 project. 1991 TW(SOLD)
    2018 Beta 300RR, 2017 FZ-07, 86 BW80 (and more)
    Jeep Wrangler- moto recovery vehicle
    Feb 2013
    145
    Still with me? Great! So, here we go.
    1)- SUSPENSION. This was my main problem with the TW, and also one of my favorite things about it. What? Huh? Yeah! The suspension on my TW was poor for higher speed off-roading, but it allowed a low seat height and comfy ride on fire roads. See? Good and bad. I frequently bottomed the suspension riding on whoop trails. My next step with the TW was to try some stiffer pro cycle springs, but I decided that I'd never be able to truly fix it due to the short travel. So, the WRR definitely wins this category for my style of riding. The WRR suspension seems great so far. Yeah the shock may need some tuning, but it's long travel (11") and soaks up bumps nicely. I can easily carry quite a bit more speed when the trail gets rough. This suspension is plush on road, and great offroad too. It's hugely confidence inspiring offroad.
    2)- RIDE HEIGHT. This is closely related to suspension, but deserves its own category as its a huge pro for the TW. I'm 5'9" and about 200lbs geared up, 29-30" inseam. The TW was super comfy for me, I could flat foot the bike with bent knees. It was great for slow speed exploration and going "boldly where no rider has gone before." Unfortunately, I didn't do enough of this to justify the performance I was giving up. The WRR has a claimed stock seat height of 36.6 inches, and a tall rear fender. This gets even taller once you replace the stock tires with real knobbies. These combined make it an intimidating machine at first. But, they had to put those 11" of suspension travel somewhere. Once i'm moving past a walking pace, I no longer notice the height. Anyhow, I was able to adjust the shock to bring the bike about an inch lower. But with my aggressive tires, I'm still measuring over 36" at the lowest part of the seat. It works for me, but I have to make sure I stop on level ground, and lean to one side. Similar to how I ride my motocross bikes. I have no plans to lower it further.
    3)- ENGINE. Huge win for the WRR, obviously. It's not so much the increase in power, but usability. The WR is fuel injected. This is a huge improvement for me. Ease of starting, less warm up, and ridiculous throttle response. Plus, higher reliability. I know, I know.., I'll address that in a minute. The WR also has a 6 speed wide ratio (get it? WR?) transmission that allows a range of gearing choices. The TW had similar power right off idle (maybe up to 2000 RPM?) and after that the WR pulls away. I frankly was surprised at how powerful the WRR feels. I wasn't expecting much from a four stroke 250 tuned for reliability. I am able to easily spin the rear tire off road, loft the front tire on command, and even steer the bike just with throttle like you would a MX bike. Very fun stuff! The TW and WRR seem to produce a similar exhaust volume, both are nice and quiet stock. The WRR makes less internal engine noises, but it's also newer. The WRR has a 26,800 mile valve service interval. The TW has a backup kick starter, which I miss on the WRR. I'll have to closely monitor the battery.
    4)- MAINTENANCE. Tough call. While the TW is a simpler machine, mine was 22 years older than the WR. Consequently, it had been worked on by some people who... Let's just say they shouldn't be working on motorcycles. It was mostly stock, but I was fixing lots of issues due to mismatched hardware and simply age. Rubber and seals wear out. This can't be a negative for all TWs, as many people are riding TWs newer than my 2013 WRR, just mine in particular. My particular WRR still has a several years left on its factory extended warranty. I've never had a motorcycle with a warranty before! But regardless, both bikes are known to be super reliable. They both require regular servicing of chains and tires etc. The WR had a fuel pump failure issue on early 2008 models, but that has since been fixed with a redesigned fuel pump so I don't anticipate any problems. The WRR has more choices in tires due to its more common wheel sizes. If I choose to open up the bike with air box mods and exhaust, I will have to purchase a fuel programmer like the "power commander v" whereas on the TW I'd just buy a handful of jets. So, more expensive but easier. Routine stuff like oil changes are very similar. The WR has almost the exact same oil filter setup as the TW.
    5)- ROAD RIDING. This was interesting. My TW was great up to about 45-50mph. 45 was its happy place. It topped out, wide open, around 65 mph. But riding regularly at that speed for me was out of the question. The bike was screaming, and running hot. After high speed runs, I'd see oil weeping out of the cylinder base gasket which never happened when I was kind to the bike. Roads to the woods are 50-55mph speed limited, and cars go faster. I was forever running the slow lane, or pulling into the shoulder and letting cars go around me. You could say that the engine was the limiting factor on the TW. On the WR, it's happy place seems to be around 65mph. I've seen 80, and it still had plenty left. This bike is limited by my tire choice only. Above 75 or so, the front knobby gets a nice speed wobble / wander which is a bit scary. A good set of road tires would prevent this, but that's not my mission as you know. 6th gear is wonderful. The WR is so quiet that wind and tire noise completely blocks the engine out above ~50mph. I wish Yamaha would update the TW with 6th and fuel injection.
    6)- LOW SPEED HANDLING. Here, the TW wins hands down. Below 5 mph, the low seat height, low gearing and fat tire balance just make the TW unstoppable. The WR is tall, so it's hard to make a tight offroad u turn in uneven terrain. Also, it has a very abrupt off idle throttle response that is a bit annoying. Several fixes are discussed on the WR forum, I'll report back with which one I choose. Lower gearing (larger rear sprocket) would help here.
    7)- GENERAL. I'm really happy with my WRR. It's the plated dirtbike I wanted. It will run fast trails, jump, and slide. I love the fuel injection for ease of use and efficiency. It's great to be on a modern bike again. My TW, being a 1991, had the old handlebar switchgear and no trip meter. Little things but the modern stuff on the WRR, including digital dash with fuel light, is just great to have. I do miss my little tractor TW, and would never have sold it if I could afford to buy the WRR without selling. That being said, I'd like to get another one someday as a companion to my WRR for slow offroad exploration. Different missions, different bikes.
    admiral, Elvesus, jbfla and 7 others like this.
    -Travis
    Feb 2013
    145
    And now everyone's favorite part. Pics!!!
    My TW when I bought it. Spray painted, street tires, sad thing.
    Then after a few years of enjoyment, this is how it looked when I sold it.
    admiral, Ken, jumpinjoe and 1 others like this.
    -Travis
    Feb 2013
    145
    My WR250R, strapped to my jeep for the ride home from the dealership! I'm the second owner, it was traded in to a marine dealer with just 395 miles.
    Out in her natural habitat!
    I hope this helps anyone shopping for a higher performance replacement to the TW200. I'll continue updating this thread with riding pics etc, so as not to contaminate the rest of the TW forum with WR pics! Thanks for reading!
    admiral, Peterb, Ken and 1 others like this.
    -Travis
    Nov 2011
    norcal nutjob
    3,303
    that's a good-looking bike. thanks for the review
    Prime and jtomelliott49 like this.
    Senior Member Rhodetrip's Avatar
    Aug 2010
    Out wandering around
    1,930
    Thanks for posting! That's a well thought out comparison. I have friends with the WR and everyone loves them.
    "Me and Mrs Trip, we got a thing going on"... an on-going adventure...
    "When Piggies Fly" ...Me & Mrs Trip Cross the Pond
    "Take the Puppy to the Beach"...a dirt route across southern New England
    Latest Spotwalla: Hidden Content
    Senior Member TWROG's Avatar
    Dec 2014
    Stockbridge GA
    807
    Im jealous
    2009 TW200 "Cracker" - His fun ADV bike
    2006 TW200 "Blue" - Her fun ADV bike
    2011 XL1200X "48" - My cool bike
    1977 KZ650 - My vintage sport bike
    Feb 2013
    145
    Check it out guys, my first mod!!! Courtesy of a super slow speed u-turn, and I stalled the bike which tipped me over. This is what I get for riding without barkbusters. I'll be ordering those asap.
    littletommy, admiral, Fred and 2 others like this.
    -Travis
    Feb 2013
    145
    I added a new category, 6)- LOW SPEED HANDLING, to my original post. Check it out above!
    -Travis
    Senior Member Werloc's Avatar
    Nov 2013
    Central, NJ
    1,983
    Travis, great job on review, and very nice writeup for sure. Just can't wait to ride dude. Nice and cool today, but waiting on goodies for my bike. I pick my trailer up next Tuesday.
    Bob
    When in doubt, Gas It..!!!
  1. Yamaha TW200 of Yamaha XT250
    By Don in forum General Discussion
    Last Post: 08-31-2017, 11:11 PM
  2. Considering replacing WR250R with TW
    By Robbo in forum General Discussion
    Last Post: 03-21-2016, 05:47 PM
  3. Replies: 9
    Last Post: 05-31-2015, 08:02 AM
  4. Dumb question - WR250R sub frame is steel?
    By kj7687 in forum Other Bikes
    Last Post: 02-14-2015, 11:41 AM
  5. WR250R vs. CRF250L vs. KlX250S
    By kj7687 in forum Off-Topic
    Last Post: 03-24-2013, 03:06 PM
yamaha tw200 near medford nj
