Why in the world do the DRZ rims have two valve stem holes?
Results 1 to 10 of 18
Like Tree20Likes
Thread: Why in the world do the DRZ rims have two valve stem holes?
    Senior Member Borneo's Avatar
    Feb 2014
    6,368
    They are, I believe, Excel rims. No reason to believe they are not stock. One hole has the tube stem, the other is plugged. One is a few inches from the other, both on the flat. Weasel noticed it and pointed it out. He asked me and I had to confess ignorance. Anyone?
    my blog Hidden Content
    Mar 2015
    Ynys Môn
    4,549
    Rim lock ?
    admiral likes this.
    - Hidden Content
    Senior Member buellzebub's Avatar
    Oct 2015
    Breedon on the Hill, UK
    324
    2nd hole is for a Rim Lock to prevent the tyre and inner tube from slipping on the rim and ripping the valve off when running low pressures 👍
    admiral likes this.
    Feb 2014
    6,368
    I'm very familiar with rim locks Purple, but I've always mounted them 180 degrees from the valve stem...can't say why, that's just how I was taught. Think that's it eh? Seems too close to the valve stem...but what do I know, maybe close is better in terms of protecting the stem.
    Feb 2014
    6,368
    Sent from my SAMSUNG-SM-G900AZ using Tapatalk
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,300
    Quote Originally Posted by Borneo View Post
    I've not seen them so close to the stem but it makes perfect sense, hole the tire to the rim as close to the stem in case of a flat, less likely to damage it if the tire starts moving on the rim.
    Borneo likes this.
    Mar 2015
    Ynys Môn
    4,549
    I just included the vid for others cruising the site - figured you'd used them before
    Closer to the valve stem would make more sense - less chance of the deformation of the tire ripping it out - but I suspect there will always be differing opinions on that .......
    Borneo likes this.
    - Hidden Content
    Feb 2014
    6,368
    Well, I think I agree with the closer to the valve the better analysis, but that's what threw me. Now I wonder why all us guys mounted them 180 from the stem back in the day...somebody started that.
    Mar 2015
    Ynys Môn
    4,549
    Probably Hoot ......
    Borneo and TWilight like this.
    - Hidden Content
    Feb 2014
    6,368
    Research says the new conventional wisdom is close to the stem and in front of it as considering the direction of spin...which means that puppy is right where it ought to be. Thanks for clearing it up guys. I guess the days of drilling your own hole directly across from the valve stem are way past. The shroud of vintage darkness has parted for me.
  1. Steering Stem Question (Older vs Newer)
    By mbld in forum Technical Help
    Last Post: 08-25-2014, 05:00 PM
  2. YAPLFASS -- Yet Another Person Looking For A Steering Stem
    By mmclaughlin in forum TW200 Classifieds
    Last Post: 08-19-2014, 03:44 PM
  3. WTB: 2001+ Steering Stem
    By mbld in forum TW200 Classifieds
    Last Post: 08-15-2014, 03:03 PM
  4. Rims......why not TW's.
    By frog13 in forum General Discussion
    Last Post: 11-17-2013, 08:53 PM
  5. valve adjusters: intake valve died, who fights next?
    By jontow in forum Technical Help
    Last Post: 07-14-2011, 10:24 PM
excel rims tube stem style
rim with two valve stem holes
rims with 2 valve stem holes
rims with two valve stem holes
rims with two valve stems
what car has two valve stem holes
