Wood Motorcycle
Results 1 to 6 of 6
Like Tree3Likes
  • 2 Post By scotti158
  • 1 Post By phelonius
Thread: Wood Motorcycle
    May 2013
    Groton, NY
    2,663
    Wood Motorcycle
    Fred and brushhippie like this.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    Nov 2010
    Frostbite Falls Ill
    2,719
    With a make and break engine. Very unique.
    Phelonius
    Senior Member plumbstraight's Avatar
    Montesano, Washington
    2,712
    At first I thought it was a hit miss, but I believe by the sound it is a diesel. Notice how he got it spinning before closing the compression relief to start it?
    18,595
    Termites would love it! Impressive craftsmanship, only fitting it has as unique an engine as its frame.
    Nov 2010
    Frostbite Falls Ill
    2,719
    Quote Originally Posted by plumbstraight View Post
    That's exactly the way I used to start my gasoline make and break engine, and it is how the centrifugal governor worked too. The centrifugal weights moved a rod that held open the exhaust so that the piston couldn't suck in air fuel mix. When RPM dropped enough, it would release the rocker allowing the valve to work as normal and the piston fired.
    There was no cam or rod or rocker for the intake valve. It had a very light spring and as the piston went down the suction opened the valve to admit fuel air mix.
    Phelonius
    Nov 2010
    Frostbite Falls Ill
    2,719
    Does it use linseed oil?
    admiral likes this.
    Phelonius
  1. Idea for you wood workers.
    By ZDR1 in forum Off-Topic
    Last Post: 08-28-2015, 12:26 PM
  2. A New $3,000 ADV Motorcycle? Yes, Please!
    By littletommy in forum Other Bikes
    Last Post: 08-09-2015, 09:54 AM
  3. Replies: 1
    Last Post: 02-17-2015, 12:54 PM
  4. What motorcycle to take??
    By mga60tw in forum General Discussion
    Last Post: 05-14-2012, 03:05 PM
  5. Got my first motorcycle!
    By Beewerks in forum General Discussion
    Last Post: 05-20-2011, 08:35 AM
