Found a DR 350
Results 1 to 10 of 17
Like Tree13Likes
Thread: Found a DR 350
    Banned ZDR1's Avatar
    Feb 2014
    Arizona
    4,030
    Found a DR 350
    Found a low miles DR-350 in very good condition and see that Procycle has me covered will look good in-between my DR650 and TW.
    JagLite and kj7687 like this.
    Apr 2014
    Dryden NY
    6,336
    Quote Originally Posted by ZDR1 View Post
    You know Paul, just because you can single handedly save the faltering economy, it doesn't mean you should!
    Tom
    TWilight likes this.
    Senior Member JagLite's Avatar
    Aug 2010
    Anchorage, Alaska
    551
    Excellent choice!
    I have been watching for one locally too but so far I'm still looking...
    James
    ______________________
    Attitude =
    The difference between
    Ordeal and Adventure
    Senior Member plumbstraight's Avatar
    Montesano, Washington
    2,712
    I was looking at one of those in the local showroom. Reminded me of those gals doing the balance beam. Riding on that narrow seat would be a B buster not to mention way to high off the ground.
    ZDR1 likes this.
    Feb 2014
    Arizona
    4,030
    Well if I get this it is for my son so he can tag along and I will be on my dr650. but I get the fun of the mods!
    Mattwings likes this.
    Feb 2014
    Arizona
    4,030
    Quote Originally Posted by plumbstraight View Post
    PS this is a older bike very low to the ground set is ok but I will replace and put a plastic desert tank on.
    Feb 2014
    Arizona
    4,030
    I think you are thinking about a DRZ-400 seat height is around 39 inches.
    18,595
    Sorry folks, couldn't find the seat height for the Trivia Bowl but here is other info that make the DR-350 sound rather attractive:
    Suzuki DR 350 S
    Manufacturer Suzuki
    Successor DR-Z400
    Class dual-sport
    Engine 349 cc (21.3 cu in) 4-strokesingle
    Bore / stroke 79.0 mm × 72.1 mm (3.11 in × 2.84 in)
    Top speed 87 mph (140 km/h)[citation needed]
    Power 33.4 hp (24.9 kW)[citation needed]
    Torque 25.6 lb·ft (34.7 N·m)[citation needed]
    Transmission 6-speed
    Frame type Diamond steel
    Brakes Disc
    Weight 286 lb (130 kg)[citation needed] (wet)
    Fuel capacity 9 L (2.0 imp gal; 2.4 US gal)
    Copied from Wikipedia:
    The Suzuki DR350 is a 350cc single cylinder, dual-sport motorcycle introduced in 1990. The DR350 S and DR350 R were kick start motorcycles until 1994 when the DR350SE was introduced adding an electric start. It has a 349-cubic-centimetre (21.3 cu in) single cylinder overhead cam (OHC), with the Suzuki Advanced Cooling System (SACS), dry sump lubrication, 6-speed transmission, 21-inch front wheel and 18-inch rear wheel.
    As you can see the 350cc was replaced with the 400cc just about the time the world ended with Y2K back in 2000.
    TWilight and JagLite like this.
    Senior Member Xracer's Avatar
    Lake Placid,Florida
    3,750
    Nice bike. They are real hard to find around here.
    Aug 2010
    Anchorage, Alaska
    551
    Keep in mind that there are three DR 350 versions.
    One street legal, among other things it has a cush hub that the other two don't.
    One is pure dirt, the other is dirt with headlight/taillight.
    Listed seat height is 35.6"
    The weight is a really nice selling point since it is about 100 lbs lighter than the DR 650 for the street legal version, the other two are even lighter.
    admiral likes this.
    James
    Attitude =
  1. Found a little starter for my son
    By SickPuppy76 in forum General Discussion
    Last Post: 11-15-2015, 09:14 AM
  2. Go Pro found.
    By ZDR1 in forum Off-Topic
    Last Post: 09-16-2015, 08:42 PM
  3. Found an 09!
    By Logsplitter in forum General Discussion
    Last Post: 03-20-2014, 07:53 PM
  4. Look what I found under the tree...
    By FishByte in forum General Discussion
    Last Post: 12-29-2013, 01:24 PM
  5. Found this on youtube...
    By tcepilot in forum Off-Topic
    Last Post: 11-03-2013, 06:04 AM
