XT350 tank with motorcycle attached
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Like Tree45Likes
Thread: XT350 tank with motorcycle attached
    19,069
    We seem to have threads here about looting XT350 tanks to put on our TWs, but anyone have experience with the actual XT350? Nice 2000 one locally for $1,800 and I am curious if it would make a worthwhile stablemate.
    .2000 Yamaha XT 350 Dualsport
    Senior Member Peterb's Avatar
    Apr 2011
    North Bay, Ontario, Canada
    1,488
    All I know is the tank is to big but if you buy it we might be able to make a deal. Just trying to help you out Fred.
    jtomelliott49 and GTG like this.
    19,069
    I was reading the 2000s, at least in the UK, were de-tuned to 18 hp. 6 speeds and 90 mph but geared too tall with too weak suspension for serious trail work...difficult kick-start only. hmmm, some advice is to get a DR instead.
    jtomelliott49 likes this.
    Jun 2014
    Bel Air Maryland
    4,170
    Cool bike but the seat height is to high for me.
    General information
    Model: Yamaha XT 350
    Year: 2000
    Category: Enduro / offroad
    Rating: 65 out of 100. Show full rating and compare with other bikes
    Engine and transmission
    Displacement: 346.00 ccm (21.11 cubic inches)
    Engine type: Single cylinder, four-stroke
    Power: 27.00 HP (19.7 kW)) @ 8000 RPM
    Max RPM: 8500
    Compression: 9.0:1
    Bore x stroke: 86.0 x 59.6 mm (3.4 x 2.3 inches)
    Valves per cylinder: 4
    Fuel system: Carburettor. Teikei Y24PV
    Fuel control: Double Overhead Cams/Twin Cam (DOHC)
    Ignition: C.D.I Magneto
    Lubrication system: Wet Sump
    Cooling system: Air
    Gearbox: 6-speed
    Transmission type,
    final drive: Chain
    Clutch: Wet, mulyiple disks
    Chassis, suspension, brakes and wheels
    Frame type: Diamond
    Front suspension: coil spring / oil damper
    Front wheel travel: 255 mm (10.0 inches)
    Rear suspension: coil spring / gas-oil damper
    Rear wheel travel: 73 mm (2.9 inches)
    Front tyre: 3.00-21
    Rear tyre: 110/80-58P
    Front brakes: Single disc
    Front brakes diameter: 245 mm (9.6 inches)
    Rear brakes: Expanding brake (drum brake)
    Rear brakes diameter: 130 mm (5.1 inches)
    Physical measures and capacities
    Weight incl. oil, gas, etc: 130.0 kg (286.6 pounds)
    Seat height: 855 mm (33.7 inches) If adjustable, lowest setting.
    Overall height: 1,210 mm (47.6 inches)
    Overall length: 2,240 mm (88.2 inches)
    Overall width: 865 mm (34.1 inches)
    Ground clearance: 275 mm (10.8 inches)
    Wheelbase: 1,420 mm (55.9 inches)
    Fuel capacity: 12.00 litres (3.17 gallons)
    Reserve fuel capacity:
    Feb 2015
    Maple Ridge, BC, Canada
    1,599
    I owned a 97.
    Heavy on the trails, I geared it down fo trail riding and changed the front sprocket for when doing more road riding.
    Ok fire road, FSR bike.
    Lots of vibration on the road. Coming down the Hope Slide Hwy 3 Do 70 mph The front fender caught a wind gust and I was starting to Wheelie ( almost a diaper moment)
    I stuffed the piston on SFU hill and need to have it rebored and over size piston and rings. ( I was young and rode my bikes hard)
    Overal good Yamaha quality bike. A WR250r is a way more versatile bike.
    Feb 2015
    1,599
    Fred it was easy to Start, A XR 400 is a pain too start.
    I also bent the front forks hitting a boulder at 40 mph. Bike faired better than I did.
    19,069
    Thanks Eckhart.
    Was sort of hoping to find the excitement of an KTM EXC with the reliability of a low stressed thumper, something like a DRZ.
    Indeed once I helped ride a stranger's XR400 out of a difficult trail that had the elderly gentleman owner too intimidated to continue. The XR seemed hard to start on a sidehill and geared too high for the technical nature of that cliff lined trail.It was a handful. After I hiked back up to retrieve my bike the TW seemed calm and comfortable by comparison.
    Biking through Africa with Cornelis
    17,595
    Normally I'd say that was a good bike and I would ride one happily, but this one? Hmmmm Look at the scraped up side cover and the pool of something under the bike. The scratches on the bike makes it look like it slid down a hill without its rider. I bet there is more work needed on this one than you know to make it a good dependable bike. I'm pretty fussy about my "keepers", I would have walked right away from this one. I think "if" you are wanting one of these bikes, I'd look for another one.
    ejfranz and jtomelliott49 like this.
    1st John 1:9
    John 3:16
    John 3:17
    Mar 2015
    Northville, MI
    779
    My XT350 was reliable, fun to ride and cheap. Suspension was weak, swingarm limited tire size and it was not light. Started super easy, every time. Mine was the YDIS twin carb model. It made a little more top and bottom end with the progressive throttle linkage and smaller throtle bodies. I would have another for a trail cruiser if the right one came along. Watch for base gaskets and carb boots.
    Frosty Hollow
    13,174
    They are tempting aren't they? A few have mentioned a lot about the XT I would now not consider it, that and no magic E button is a no go nowdays.
  1. XT350 or XT 250 Tank Bag?
    By HKLBRY in forum General Discussion
    Last Post: 03-24-2015, 05:34 PM
  2. xt350 tank
    By joeband in forum TW200 Classifieds
    Last Post: 03-09-2014, 08:32 AM
  3. XT350 tank and Banshee shock (tank sold)
    By Beewerks in forum TW200 Classifieds
    Last Post: 08-30-2012, 09:01 AM
  4. WTB xt350 tank
    Last Post: 11-30-2011, 12:18 PM
  5. XT350 gas tank...does it fit?
    By glas482 in forum Technical Help
    Last Post: 02-03-2011, 04:03 PM
