Fuel line to connect 4 carbs together - what size inner diameter hose to use???
Results 1 to 5 of 5
Like Tree5Likes
  • 2 Post By Smitty Blackstone
  • 2 Post By kj7687
  • 1 Post By Smitty Blackstone
Thread: Fuel line to connect 4 carbs together - what size inner diameter hose to use???
    Senior Member kj7687's Avatar
    2,422
    Question Fuel line to connect 4 carbs together - what size inner diameter hose to use???
    So, I've been working on a friend's bike. Long story short, the fuel line that should connect the four carbs together was missing...just completely gone. I'm thinking I will try to cut some fuel hose and use it to connect the carbs. The problem is, I don't know what size the original connectors were (and they aren't sold independently as per the parts diagrams for the carbs). The outer diameter of the hard line that comes out of the side of each carburetor is 6 mm. I have a ~4 mm inner diameter vacuum line that seems to fit pretty well, and a ~5 mm inner diameter fuel hose that fits, but seems slightly loose. I'm concerned that the 5 mm line could leak, but don't trust the 4 mm line to hold up/not get eaten by the gasoline eventually. I am thinking to buy this: https://www.jetsrus.com/individual_p...532932_50.html . I guess I just want some kind of reassurance that 4 mm i.d. hose is reasonable to use with 6 mm o.d. outlet tube (on the carbs)...
    Of course, it doesn't help that the outlet tubes coming off the sides of the carbs are very short in length - probably 1/4", so there is also some concern of whatever hose I stick in there not necessarily staying put super well. I'm planning to cut each hose about 1 or 2 mm too long, so that the carbs push the hoses together a little and help hold them in place.
    KJ, just KJ, ok.
    Current rides:
    Sep 2014
    Mamaroneck, NY
    2,196
    If the 5mm is loose, use 4mm FUEL RATED tubing.
    littletommy and arbolmano like this.
    Skiing the slopes in Switzerland
    17,587
    Use the smaller tygon.
    1st John 1:9
    John 3:16
    John 3:17
    2,422
    Alright, thanks for the responses. I'll go ahead and order up a foot of the tubing in my link. I just wish I had another three months of summer vacation to finish this "little" project...
    KJ, just KJ, ok.
    Current rides:
    Sep 2014
    Mamaroneck, NY
    2,196
    There is never enough time...
    Sent from my SM-N920P using Tapatalk
    littletommy likes this.
  1. Replies: 7
    Last Post: 08-28-2016, 03:30 PM
  2. Fuel hose diameter
    Last Post: 08-19-2013, 05:12 PM
  3. fuel hose routing
    By bikerjosh in forum Technical Help
    Last Post: 02-18-2013, 05:24 PM
  4. Fuel Line Diameter ID?
    By Snake2715 in forum Technical Help
    Last Post: 06-18-2012, 08:42 PM
  5. Front Fork tube size diameter/seal&dust boot kit
    By bruisr in forum Performance and Customization
    Last Post: 02-19-2011, 07:07 AM
