Could (or should) an SR400 be modified for forest roads?
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Like Tree115Likes
Thread: Could (or should) an SR400 be modified for forest roads?
    Senior Member Cascade Rider's Avatar
    Sep 2017
    Kent, Washington
    123
    While looking at a TW at my local cycle shop the other day I walked by a new SR400. Just like you never forget your first girlfriend, I immediately remembered how much my Honda CB550 delighted me in my 20's. My future riding will be split 50-50 between quiet exurban streets and mountain forest / logging roads. While my mind says look away, my emotions say otherwise. To use the girlfriend analogy again, there were women who I knew weren' t good for me but the attraction was mighty strong.
    Is it feasible (or wise) to take anSR400 with appropriate tires into the mountains?
    SR 400: seat height 31, wet weight 384, tank 3.2, rear wheel travel 4.1, front travel 5.9, front tire 90/100-18, rear 110/90-18, EFI. My hitch is rated 500 lbs.
    I never listened to my father when he warned me about some of my girlfriends, but hopefully I am a little smarter now.
    Ken, jtomelliott49 and PlacerLode like this.
    God made mud. God got lonesome. So God said to some of the mud, "Sit up!" "See all I've made," said God, "The hills, the sea, the sky, the stars." And I was some of the mud that got to sit up and look around. Lucky me, lucky mud. I, mud, sat up and saw what a nice job God had done.
    Kurt Vonnegut, Cat's Cradle
    Senior Member Xracer's Avatar
    Lake Placid,Florida
    3,786
    You can get that 60's vibe by trying to make it into a dirt bike. Other than that their are much better choices for what you want to use it for.
    Senior Member Fast Eddie B's Avatar
    May 2017
    Mineral Bluff, GA
    208
    I’d say go for it.
    With enduro tires and maybe a higher front tire, I’d think it would get the job done on mild off-road excursions. Think about what some manage with BMW GS’s!
    Do a Google image search for “Yamaha SR400 dirt”. One hit:
    Mar 2015
    Ynys Môn
    4,592
    Do a search for SR400 flat tracker and things get more interesting ....
    Ken, PlacerLode and Tweaker like this.
    - Hidden Content
    May 2013
    Groton, NY
    2,663
    My advice is to do only bolt on mods, that way you can go back to stock with little hassle and "trade in" your girlfriend if needed.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    Sep 2017
    Kent, Washington
    123
    Yamaha SR400 stock and forest road modified
    Lake Placid,Florida
    3,786
    OK I take back what I said. Go for it! Just make sure to get a good skidplate and take lots of pictures.
    Jan 2017
    Southern Nevada
    1,077
    I had similar thoughts, but Yamaha of Las Vegas parts manager, who rides a TW and has given a knowledgeable answer to every question, re TW and XT, commented that the SR400 did not have much power…his seat of the pants feel, after riding it.
    - The SR400 is 24 HP @ 6,400 with 7,000 redline (XT is ~ 17 HP). Using the displacement ratio of 249:399, the S400 should have about 27 HP to be proportionate.
    - 21 ft lbs at 5,500 (XT is 14.5 ft lbs). Using the displacement ratio of 249:399, the S400 should have about 23 HP to be proportionate.
    - Reviews mention vibration over 60 (XT250 is smooth to 70+)
    - The SR400 weighs 384 pounds (XT250 is 291, 93 pounds lighter)
    + The SR400 3.2 gallon tank at 66 MPG can go 211 miles (XT250 2.6 gallon tank at 76 MPG can go 197 miles)
    + The travel on the front forks of a SR400 is 3 inches less than a XT250.
    + The SR400 seat is an inch lower than the XT250.
    + Might be easier to find scrambler tires for the SR400
    https://www.yamahamotorsports.com/sp...0ab6452c51d523
    Just my 2 cents, but probably why I went with the XT250…for now.
    2014 Honda CB1100
    2018 Yamaha XT250
    2016 Moto Guzzi V7 II
    2017 Yamaha TW200
    2012 Triumph Bonneville
    2002 H-D Sportster 1200 Sport
    2003 H-D Sportster 883
    1976 Honda CB750F
    1975 Honda CB360
    1970 Yamaha CT1
    1972 Yamaha CT2
    1972 Yamaha AT2/CT2
    1970 Honda SL350
    1970 Honda CL350
    1967 Honda CL160
    1967 Honda CB160
    1962 Honda CA110
    Feb 2017
    Waretown NJ
    556
    Sure you could. They raced mx on bikes not that unlike it back in the day. But that's because there were no better choices back then. I do like that bike for the road though . If you have a bug up your butt for one to ride on dirt roads,go ahead and do it. Only you need to be happy with your decision . You can always sell it if it's not what you want. I wish that 400 motor came in the TW
    jtomelliott49 and Pete H like this.
    87 TW
    Nov 2010
    Frostbite Falls Ill
    2,719
    In 78 I bought one of the new SR 500s. I lived in Klamath Falls Oregon then so there was no shortage of off roading opportunities.
    I began going off road with it often, deserts, mountains. I didn't even change tires. There was a great hill climb about a mile from home where all the rugged dirt bikes tested themselves. One day on a whim I pointed the SR 500 up the hill and let her rip. Up on the pegs forward against the handlebars, A quarter mile up I cleaned the hill and stopped in front of a gawking group of dirt bike riders who just stared. They had not expected to see a pavement bike up there, much less with a windshield. I greeted them and went back down. Next time I was at the Yamaha shop I was hearing stories about how some dirt riders had seen a road bike like mine go up the hill climb and clean it.
    Sure, I crashed a few times so I traded it for an enduro.
    Phelonius
  1. Roads? Don't need no stinking roads!
    By phelonius in forum Other Bikes
    Last Post: 12-20-2015, 12:15 AM
  2. Yamaha SR400
    By roost131 in forum TW200 Classifieds
    Last Post: 12-15-2014, 07:18 AM
  3. Yamaha SR400
    By frog13 in forum Off-Topic
    Last Post: 04-24-2014, 06:44 AM
  4. dirt or forest roads near dayton tn.
    By jpuck in forum Trails, Off-road, and Adventure Riding
    Last Post: 03-10-2012, 09:47 PM
  5. Street legal bike, Forest Service roads, unlicensed rider?
    By MrDNA in forum General Discussion
    Last Post: 04-25-2011, 08:59 PM
