air filter modification - help
Results 1 to 3 of 3
    Junior Member tokey's Avatar
    Nov 2010
    7
    i have a 2003 tw200 . . . absolutely love it . . .
    i am interested in "cleaning up" the bike a bit and want to remove the air filter (and all of the plastic on the left side of the bike under the seat).
    has anyone done this type of modification and if so, what much smaller air filter have you used? any problems that you have run into or suggestions would be great. thank you in advance.
    Member r_marsh's Avatar
    Aug 2013
    Fort Worth
    45
    I recently did mine. The battery box is another story to deal with but you should be able to bend some sheet metal and rivet a box together to mount. Many people who have done the hollow mod have recommended using the K&N RU1780. Its big and red and looks tough, I hated it and it didn't work for me. No matter what air filter you use, the shock is simply too close to the carb to have anything fit, ergo don't throw away the rubber diversion tube when you remove the stock airbox. The problem with the k&n was that when attached to the tube, it was too heavy where it slipped on to the carb and would fall out on me when I rode. I didn't want to rig up some zip tie solution. Its also big and tended to hit my leg where it protruded from the frame. I cant remember what I have on now but I simply went to the local moto shop and ordered the smallest 'mushroom' type filter I could get that would fit on the rubber tube, and I spent $12 compared to the $45 I originally spent on the k&n.
    Apr 2013
    385
    when i did my first hollow mod i cut the original air box down and was just left with the part that holds the battery, i cut it in a way that i left the original attachment holes., with filter i did the same as r marsh, kept the 3" tube that connected it to the carb and just bought a cheap cone filter
  1. Dual Headlight Modification
    By r_marsh in forum Performance and Customization
    Last Post: 03-13-2014, 03:57 PM
  2. Rear shock modification for control/comfort
    By Gerry in forum Performance and Customization
    Last Post: 09-01-2013, 06:45 AM
  3. Seat modification for Muley
    By JS5owner in forum Performance and Customization
    Last Post: 12-15-2011, 09:30 AM
  4. Muguard modification
    By Sly Fox in forum Performance and Customization
    Last Post: 04-03-2011, 12:18 PM
  5. stock muffler modification
    By tripleted in forum Performance and Customization
    Last Post: 03-09-2011, 08:10 PM
tw200 hollow air filter
tw200 hollow mod air filter
tw200 k&n air filter modification
