Speaking of jetting for altitude...
Results 1 to 10 of 12
Like Tree8Likes
Thread: Speaking of jetting for altitude...
    Senior Member Adam-n-nevada's Avatar
    High Desert, Reno area in Nevada
    441
    I've always wondered the following question:
    Please take into consideration the following:
    -I live at 4,500 feet above the level of our oceans.
    -I've never adjusted, added or changed anything in my carb.
    -Bought her new, she's an 06' Non-cali model
    -My travels in the area range from 3,500 ft - 9,000 ft
    She's always seemed to run fine. But, could it run better?
    -Adam
    Junior Member Expat's Avatar
    Jul 2011
    Anchorage, AK
    7
    Pull the plug and check the color. That should tell you how balanced your air/fuel mixture is.
    Adam-n-nevada likes this.
    441
    They've always looked great n' normal.
    Senior Member B-dub's Avatar
    Jul 2011
    Southwest Utah
    2,132
    If you were to spend all of your time reasonably close to one altitude I would recommend rejetting for more power. However, where you ride a range of altitudes, if you were to rejet for more power at 4,500 feet by the time you got to 9,000 it would be way too rich. Conversely, if you were to rejet for more power at 9,000 feet you could very possibly be too lean at 3,000 feet. Sounds like the stock jetting is a good compromise for you, as it is for me. I say, don't fix it if it isn't broke. Just my 2 cents, though.
    441
    Thanks B-dub. What's your elevation there?
    Apr 2011
    Martinsville Indiana
    2,089
    I would leave it stock. They are a little lean at low elevation.
    Jul 2011
    Southwest Utah
    2,132
    Quote Originally Posted by Adam-n-nevada View Post
    3300', but I don't have to go far to be in the mountains.
    Senior Member HappyHiker's Avatar
    Aug 2013
    Lakewood, CO
    323
    I live at 5500 ft and have ridden up to ~9500 ft and stock jetting seems good. Start to feel a little power loss ~9000 ft. , but many have ridden their TWs over 13k passes without issue (except of course power loss due to altitude). I'm hoping to see how it does for myself at higher elevations this year. Only adjustment I have done is to the mixture screw, set at 1.25 turns out.
    Some have reported good results with adding more holes to the airbox door which can be plugged or covered with duct tape, and then uncovered at higher altitudes to lean the mixture out a bit. I figured if it was needed, I'd try this route before attempting to re-jet. +1 to B-Dub - if it ain't broke don't fix it.
    Climbers TW200 likes this.
    Frosty Hollow
    13,171
    Quote Originally Posted by HappyHiker View Post
    I am one who has drilled holes (5) in my airbox cover and I unplug when camping for several day's at high elevation. There is a noticeable improvement, then I plug the holes back up when I head back down the hill. Home elevation is about 2,400ft.
    Fred likes this.
    Skiing the slopes in Switzerland
    17,585
    Admiral, is your carb stock jetting still? At what elevation do you take the tape off?
    1st John 1:9
    John 3:16
    John 3:17
  1. Re-jetting
    By r_marsh in forum Performance and Customization
    Last Post: 06-05-2014, 12:13 PM
  2. Question on high altitude jetting/operations
    By DaveyM in forum Technical Help
    Last Post: 07-21-2013, 10:45 AM
  3. High altitude jeting
    By Woodymuler in forum Performance and Customization
    Last Post: 06-22-2013, 11:47 AM
  4. Sprockets and Mods for High Altitude Trails
    By WildernessAU in forum Performance and Customization
    Last Post: 08-02-2012, 10:47 AM
  5. Speaking of sprockets
    Last Post: 10-04-2010, 10:04 PM
