520 chain and sprocket upgrade
Results 1 to 10 of 10
Like Tree3Likes
  • 2 Post By TWrider
  • 1 Post By TW-Brian
Thread: 520 chain and sprocket upgrade
    Junior Member jeeprt's Avatar
    May 2011
    Oregon Dunes
    24
    OK I was looking at some 520 chain and sprocket sets for my TW and didnt understand the difference of the spacing and how it affected the gear ratio compared to the 428 sprockets. This looks like a great upgrade especially for a bike with a Bighorn rear tire. Can someone please enlighten me on this I currently run a stock front and a plus 1 on the rear and am happy with this.
    Thanks
    Jeerprt
    07 TW FMF Maxxis Tires
    May 2013
    Groton, NY
    2,663
    51/14=3.64 Now do the same with the 520 sprockets, rear sprocket tooth count over front sprocket tooth count. If it equals 3.64 the gearing is the same. If it's a larger number, more pulling power but lower top speed. Smaller number, less pulling power but higher top speed. (If the engine has the power to run the ratio)
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    Senior Member TWrider's Avatar
    1987 TW200 OHIO
    567
    Are you snapping 428 chains? Didn't the XT350 come with a 428 chain? If you are snapping chains it's not because of too much power. Sounds more like an alignment or maintenance issue. The 520 adds weight and robs power as well as money from your check book. If you are snapping 428's then go with a stronger grade of 428.
    16,000 lb http://sidewindersprockets.com/v-ser...art_chain.html
    Adam-n-nevada and Fred like this.
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,516
    Won't a #520 chain and it's sprockets play havoc on the counter shaft spline ?.
    Senior Member Adam-n-nevada's Avatar
    High Desert, Reno area in Nevada
    441
    I agree with TWrider; this seems like a downgrade for the minimal 13 horses that TW gives us. I think you'd really notice a loss of power with a bigger, heavier chain.
    Senior Member SHAG's Avatar
    Oct 2013
    Bradford, Pa
    983
    The 428 DID X-Ring I put on my TW is pretty stout for my high output bike....
    2013 TW200 - 8k- miles
    2018 X-MAX - 6k- miles
    Pleasanton, CA
    5,782
    Hey Jeeprt,
    A 520 chain is a much beefier chain and as a result will require larger, heavier 520 sized sprockets. Assuming that the 520 size sprockets (14 front and 51 rear) are available and will fit on your TW with acceptable clearance, this change will have no impact on your existing gear ratio.
    Just curious, what benefits do you plan to gain by going from the 428 to 520 size?
    Brian
    Quote Originally Posted by jeeprt View Post
    Thanks
    Jeerprt
    Senior Member Werloc's Avatar
    Nov 2013
    Central, NJ
    1,983
    520 size chain will stress the counter shaft bearing to much. Plus, on a little 200cc engine, it will rob power, enough to notice. I'd stay away from that mod. If your breaking chains, then buy a good quality o-ring chain. Also, make sure you don't have it adjusted to tight.
    Bob
    When in doubt, Gas It..!!!
    Pleasanton, CA
    5,782
    If you are breaking chains on your TW, I'd like to buy your bike!
    Zack likes this.
    Senior Member flyhunter3825's Avatar
    Nov 2012
    DePere, Wisconsin
    296
    I did the 520 swap on all three of my XTs and my TW and ive noticed no power loss and almost no chain stretch after the first adjustment. The 1984 XT250 had a 520 chain stock, not sure why they went with a 428 on the 350. I think that bearing at the end can withstand alot more than the engine itself can handle. Also, with an ATV tire that has much more rotational mass than a stock tire or any other dirtbikes tire, there is more energy needed to turn that tire. And a bigger chain doesnt wear and doesnt stretch to the extent the little one does with the same load. You wouldnt pull your buddy out of the mud with kite string! Beef that bike up!
    Just my 2 cents, to each their own!
  1. rear sprocket upgrade
    By matty dirtcakes in forum Technical Help
    Last Post: 05-22-2014, 05:08 PM
  2. 520 Sprocket and chain
    By msmiller in forum Technical Help
    Last Post: 08-18-2012, 03:05 AM
  3. Replies: 0
    Last Post: 06-14-2012, 04:13 PM
  4. New sprocket old chain?
    By Lido in forum Technical Help
    Last Post: 09-29-2011, 05:11 PM
  5. Chain and Sprocket
    By mga60tw in forum Technical Help
    Last Post: 09-04-2010, 01:13 AM
chain and sproket upgrades
tw200 520
tw200 larger chain and sprocket
tw200 rear sprocket upgrade
tw200 sprocket chain upgrade
tw200 sprocket upgrade
yamaha tw 200 rear sprocket upgrade
yamaha tw200 chain upgrade
