Which way should I face my Roto-Pax?
Results 1 to 10 of 15
Like Tree13Likes
Thread: Which way should I face my Roto-Pax?
    Senior Member dette's Avatar
    Dec 2013
    Whidbey Island, WA
    545
    I made a mount for my Roto-Pax gas can and I keep changing my mind on which way to face the can.
    My first inclination was filler/spout side facing right-hand rear so when the bike is on the kickstand the fuel will not be against the cap.
    Then, because I seem to have trouble getting the cap tight enough to always get a perfect seal I am wondering if I should face the filler/spout end the other direction even though it would be on the low side. Reason being, no hot exhaust on the low side.
    What are your thoughts?
    Also, how can I assure that I get a good, tight seal on that cap?
    MTLHead and ZDR1 like this.
    Pleasanton, CA
    5,782
    Quote Originally Posted by dette View Post
    My Kolpin tank came with two caps. One regular cap and one spout/filler cap. The regular cap would seal, the spout/filler cap wouldn't. If you've got a regular cap, try that one.
    dette and Fred like this.
    Banned ZDR1's Avatar
    Feb 2014
    Arizona
    4,030
    gasoline. The ignition temperature is about 495° F- you can mount it any way you want, you need a more Manley grip! or channel lock plies.
    dette likes this.
    Senior Member williamemack's Avatar
    Apr 2013
    winters in Sudbury, MA, summer on Squam Lake, NH
    363
    Hey Dette, what does a walrus and Tupperware both have in common ? They both like a tight seal !
    MTLHead and evan like this.
    I sell TW200 stickers for $2.00ea. delivered. See Hidden Content for details. Hidden Content
    2014 TW, DMO pegs, Yamaha rack, Doubletake mirrors, Jimbo shield, extended pilot screw, Snapback clock, Ebay risers, Seat Concepts, o-ring chain, Ricochet skidplate, brake leash, IMS folding shift lever, ProCycle tool tube, 130 main jet and two shims, route sheet holder, compass, temp/humidity
    indicator.
    Senior Member HappyHiker's Avatar
    Aug 2013
    Lakewood, CO
    323
    In that configuration, I'd go with the spout on the low side. One to keep it away from the muffler (I'll keep gasoline as far from any ignition sources as possible, regardless of ignition temps) , and two if it leaked it looks like it would drip to the ground rather than possibly on the bike. I wouldn't take it if I didn't trust it though. No point in carrying extra fuel if it doesn't stay contained and escapes before you use it.
    Check the gasket and make sure it's not cracked or damaged, and the mouth of the can and inside the lid is smooth. If both surfaces are good, it should seal.
    goldenhtr and dette like this.
    Dec 2013
    Whidbey Island, WA
    545
    The first time I used this fuel can I put two gallons in it and had it leak a little. This morning, I put one gallon in, tightened it as tight as I could, rode about 30 twisty miles and, so far, no leak.
    I think I need to start working out because I'm a weakling and just don't have a lot of wrist strength. This becomes clear to me every time I want to open a jar of pickles or jam....lol.
    So, I don't think the Roto-Pax can has a problem, the problem is me
    Junior Member DGrav's Avatar
    Mar 2014
    Langhorne PA
    21
    How did you mount it to the rack. I've been looking for this kind of setup.
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,516
    I forget what they are called ,but , they are made of rubber ( thin rubberish material ) and you place it around the cap your trying too open . This may assist you in getting all you can from your current grip ability .
    dette likes this.
    19,023
    Frog13, something like this? Mine are called "grip wrench" and come in two sizes.Very handy for hard to grab-n-twist things like water filter housings, automotive oil filters, large pvc pipe, etc...
    ZDR1 and dette like this.
    Jun 2014
    Bel Air Maryland
    4,170
    How many gallon Roto-Pax can is that?
  1. Military veterans face ultimatum - Pills or Pot.
    By littletommy in forum Off-Topic
    Last Post: 05-20-2016, 03:36 PM
  2. Replies: 6
    Last Post: 05-15-2014, 03:02 PM
  3. Speedometer face plate change?
    By Trikstr in forum Performance and Customization
    Last Post: 09-14-2013, 06:19 PM
  4. Why real dirt bike boots prevent face scars
    By littletommy in forum General Discussion
    Last Post: 04-10-2013, 11:26 AM
  5. Face wash happen to you ?
    By losttourist in forum General Discussion
    Last Post: 09-26-2012, 02:58 PM
cyclerack with rotopax
roto pax tw200
