10/11/12" diameter rear true atv rim!
Results 1 to 2 of 2
    Senior Member Tiny-Wheel-200's Avatar
    May 2013
    Wasilla, Alaska
    735
    Just getting started on this one. I believe someone else posted about a rear wheel conversion a long time ago, im doing a a different iteration of that project. I aim to fabricate onto the stock rear tw hub a bracket that will accept a 10/11/12 inch diameter atv rim that will be able to be offset to the right enough to run a 12 inch wide atv tire when it is offset or a 10 when it is centered. Just got the donor wheel out of the post today and cut through the spokes and started measuring. This will allow me a greater choice of tires and allow me to mount easily and run tubeless. Anyone who is looking for a 88 rear rim get in touch, I no longer need this one. Its white and a shade rusty, but solid and true. Free, you pay shipping from 99687 or local pickup in Wasilla or ANC AK.
    Check back for updates, ill post as I go along.
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,305
    Great project, can't wait to watch the progress and see the end result!
  1. Does anyone have a picture of the 1/4" rear spring spacer?
    By blackmouthcur in forum Performance and Customization
    Last Post: 02-14-2014, 05:28 PM
  2. 15" rear rims
    By ramilabban in forum Performance and Customization
    Last Post: 10-01-2013, 02:48 PM
  3. Fuel hose diameter
    Last Post: 08-19-2013, 05:12 PM
  4. DG "O" Series Slip-On Exhaust with 1" Quiet Core Silencer
    By wiso2 in forum TW200 Classifieds
    Last Post: 07-08-2013, 11:31 AM
  5. Fuel Line Diameter ID?
    By Snake2715 in forum Technical Help
    Last Post: 06-18-2012, 08:42 PM
