A Few Simple Mods Then Hit the Road
Results 1 to 10 of 15
Like Tree21Likes
Thread: A Few Simple Mods Then Hit the Road
    Member M C Toyer's Avatar
    Feb 2014
    North Texas
    85
    About midnight Friday last I finally placed my order for a Cyclerack - opted for the flat back model. It was on my front porch Monday by noon. No pics but easy install and well pleased. That motivated me to complete of a couple of others I've been putting off.
    The first was to install a cigarette lighter outlet. I already had this double outlet model with watertight caps and it fit well below the instrument panel:
    I attached the leads direct to the battery terminals and ran the 12 gauge wiring through a length of clear vinyl tubing then sealed the connection to the outlet with heat shrink tubing:
    The first accessory was my Garmin Nuvi GPS in the clear case of the QuadBoss tank bag, also a new purchase and simple install:
    I converted the terminals on my battery charger to a male cigarette plug for recharging. For now I am carrying the mini air compressor in the left tank bag, trusty pistolero in the right of course:
    I've mentioned before I generally trailer the TW to my preferred riding places as I like to camp out for a few days. I've added a few convenience items to my trailer: Ready to roll, gas and water go in tongue rack:
    to be continued
    Feb 2014
    North Texas
    85
    part 2
    I have a bikini top on the teardrop shaped frame for now. Am debating making a full canvas cover for later or possibly something solid like frp or alum. In either case the top lifts for loading. It provides some traveling protection but more importantly, shade when I arrive. The vinyl truck boxes carry all my camping gear:
    The two rear boxes swing up and away for loading the TW. On the left floor is my tent base, on the right a folding ramp:
    The rear boxes contain cooking gear, non perishable food and utensils:
    At the campsite:
    The tent base attaches to either side of the trailer and can be used with several different tents or just as a bed:
    tcepilot, Padilen, Bagger and 6 others like this.
    Senior Member Padilen's Avatar
    May 2014
    Cadillac Michigan area
    1,598
    Please
    Come to Michigan and help me with my trailer ideas.
    Senior Member tinman tim's Avatar
    Jan 2012
    northeast ohio
    503
    Very nice, well thought out rig.
    SeatConcepts,carb mod,Shinko tires,15/50 o-ring chain,custom racks f/r, aluminum luggage,windshield,handguards,heated grips,Clarke tank,high frt fender,led running lights,folding shifter, wide pegs,12v outlets,headlight kill switch,voltmeter,stainless header,2nd brakelight,GPS/phone mount
    Senior Member Leben's Avatar
    Feb 2013
    Iowa
    264
    Very cool!
    Pleasanton, CA
    5,782
    Very nicely done!
    Since everything else has been so well thought out, I am guessing that you have also devised a clever way to secure your bike to the trailer. Any details you can share?
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,305
    Cool!
    Feb 2014
    North Texas
    85
    Thanks -
    Before I took delivery of my TW in January I already had the trailer, but the side rails had been cut away by the previous owner and the floor was rotted.
    I had just stripped everything to the frame, re-wired and painted. I also added a fold-up jack and permanently attached the titling tongue:
    To haul the TW home I threw down a sheet of 1/2" plywood and made a simple wood chock:
    After I added new side rails and a tailgate I made a few trips:
    Then I purchased this motorcycle chock from Harbor Freight: I replaced the cheesy eye and attachment bolts, drilled out the holes, and ran a 1/2" eyebolt through the floor and steel frame. I use ratchet tie downs with soft loops on the lower front forks. I have snap links on both ends of the tie downs:
    Not seen in the photo but I have a pair of blocks on the floor on both sides of the rear tire to center when loading and to keep it from hopping and a pair of tie downs from the lower frame to the stake pockets of the trailer. The trailer axle is rated at 3500# so I run the trailer tires at 20-25# to compensate.
    With the HF chock I can stand at the very rear of the trailer after walking the TW up the ramp and engage or disengage the TW to/from the chock with one hand and it is held securely while I attend to the tie downs. I had initially planned to make the ramp and tent platform dual purpose but changed to this smaller one (6' x 24") which folds in half and stores on the floor to the right of the TW.
    All the rest was just trial and error in selecting and arranging the boxes and other camping gear. I had initially planned to have a weather and bug proof sleeping area within the trailer itself, but that was either too complicated or required too much set-up time. The tent platform is entirely optional but I prefer to be off the ground and my old knees thank me.
    M C
    B-dub, TW-Brian and Bagger like this.
    Pleasanton, CA
    5,782
    Thanks M C,
    I figured that you had come up with some type of front wheel chock arrangement. Thanks for the details!
    Brian
    Banned ZDR1's Avatar
    Feb 2014
    Arizona
    4,030
    Quote Originally Posted by M C Toyer View Post
    boxes up 3495.jpgThe rear boxes contain cooking gear, non perishable food and utensils:
    At the campsite:
    If you don't mind how much$ do you have in the setup? very nice and cool love it.
  1. Simple quicky
    By wayno in forum Technical Help
    Last Post: 03-31-2014, 11:35 AM
  2. simple oil change question
    By firebrick in forum Technical Help
    Last Post: 09-06-2013, 12:43 PM
  3. A simple OEM exhaust mod.....
    By Landser in forum Performance and Customization
    Last Post: 08-18-2013, 11:20 PM
  4. Simple gun case mounting
    By rick james in forum Performance and Customization
    Last Post: 05-19-2013, 09:02 PM
  5. The simple things..
    By jontow in forum Performance and Customization
    Last Post: 08-25-2011, 12:40 PM
