stock air filter
Results 1 to 10 of 12
Like Tree1Likes
Thread: stock air filter
    Member triple3jrb's Avatar
    Missoula, MT
    98
    so after cleaning my air filter for the first time tonight, I notice that the filter and location seem really restrictive. I am just wondering if anyone has done any mods to provide more air into the carb. Seems to me you could almost ditch the hole box and put a simple k&n style filter on it and give the motor a little more air....has anyone done this? or at least noticed the same thing? After taking the side cover off, I wondered how air even got into the carb.. Seems ineffective to me!
    Member Tom Bentzen's Avatar
    Aug 2010
    Cle Elum, Washington
    53
    Personally Im not a big fan of K&N filters. The reason they flow and breath so well is because they sacrifice filtration. There are a million internet articles about filter comparisons out there. Just change your filter regularly and dont worry about it.
    Senior Member Turtle Chaser's Avatar
    Aug 2010
    Fieldbrook Valley CA northcoast
    254
    +1 for TW Joe. I like to use 90 weight gear oil on the stock filter. Takes a bit of care to get it evenly distributed and not over oiled. Someday I'll break down and buy some UniFilter oil (nice'n sticky). I wonder if UniFilter makes a replacement for the stock filter ?
    GOD BLESS & RIDE SAFE, TC____________ BC rides: Honda SL100, Honda TL125, Penton125 ISDT, KTM400 ISDT
    now riding '06 TW w/ Jimbo Window, Acerbis bushbusters, ProTaper bars w/risers, Pro Grip 737's, Osram Rally headlamp w/modulator, turn signal beeper, Kenda k270 4.00 x 18,
    triple horns w/relay, big pegs, folding shifter, tuned carb w/drilled slide, 15/50 w/D.I.D. O-ring, RedLine 20w/50, Sterns w/extra padding, extra LED brake light, xt225 brake arm, rear Cycle Racks w/hacked milk crate. Hidden Content
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,406
    Quote Originally Posted by Turtle Chaser View Post
    ... I wonder if UniFilter makes a replacement for the stock filter ?
    An air filter for the TW is not listed in the Unifilter catalog.
    jb
    Desert, SoCal
    7,369
    Quote Originally Posted by jbfla View Post
    jb
    Buy the flat filter material from Uni and cut your own.
    To get more flow out of the stock filter use mineral oil or ATF instead of motor oil. In my experience the thinner oil actually captures MORE crap than either motor oil or filter-specific oil, without choking the motor, and it's easier to clean.
    With any oil up to say 40WT it's pretty hard to over-oil a filter. Engine heat will eventually cause the excess to drain to the airbox drain within a few miles.
    Member tok-tokkie's Avatar
    Cape Town, South Africa
    88
    Here is a link to air filter tests. Having seen it I removed the K&N equivalent I had on my bike (long before i got the TW)
    http://www.dieselbombers.com/chevy-g...r-testing.html
    FL. GA, NC
    2,406
    Buy the flat filter material from Uni and cut your own....
    Thanks, lizrdbrth. I didn't realize the filter material is available by itself.
    jb
    Senior Member Adam-n-nevada's Avatar
    High Desert, Reno area in Nevada
    441
    Hey!
    While this topic is hot, I recently wondered if K&N filter oil is ok for the TW foam filter and if it would "grab" enough particulate??
    any thoughts are great appreciated...I have a freshly cleaned filter oiled with K&N oil ready to go - I'm just a bit cautious to install it
    -Adam
    Aug 2010
    254
    Ok you asked, I prefer heavier stickier oil. I have been told specifically not to use K&N oil on foam filters as it is too light. I have used all kinds of oil on these over the years and
    I like 90wt gear oil best as it is kinda sticky like UniFilter oil. But you must be careful not to use to much and work it in evenly. I started using the 90wt as I have a bottle of it that is too old for gears and didn't know what to do with it. Works great. JMHO
    Member villageidiot's Avatar
    80
    I look at it as UNI made there own filter oil for a reason, however I have been one to use 2 stroke oil on many a foam filter.
  1. Oil filter mix-up
    By accor415 in forum Technical Help
    Last Post: 07-04-2014, 09:47 AM
  2. Air filter Mod
    By jimmytanko in forum Technical Help
    Last Post: 10-03-2012, 07:41 PM
  3. oil filter
    Last Post: 07-06-2012, 10:00 AM
  4. Old oil filter
    By Lido in forum Technical Help
    Last Post: 09-11-2011, 11:14 AM
  5. K&N oil filter
    By brownie2 in forum Technical Help
    Last Post: 12-24-2010, 01:28 AM
attach aftermarket air filter to tw200
how to replace air filter on a yamaha tw200
tw 200 air filter
tw200 air box drilling
tw200 air filter
tw200 air filter remove
tw200 stock air filter
tw200 uni filter
where is air cleaner located on tw200
where is the airfilter on tw200
yamaha tw200 air filter
yamaha tw200 air filter location
