Does a 2000 engine fit on a 2006 frame?
Results 1 to 4 of 4
    Senior Member docjekyll2002's Avatar
    Aug 2013
    648
    Getting a bunch of offers to replace my engine. Chime in if you know what different years of engines will mount to a 2006 frame.
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,305
    The engine should fit, the wiring is different.
    Senior Member B-dub's Avatar
    Jul 2011
    Southwest Utah
    2,132
    I'm pretty sure you can transfer the left case cover and associated charging components from your old engine (2006) to your new engine (2000). I'm not sure if the rotating components (magneto) are different, probably are, but I don't see why they couldn't be transferred as well. I'll see what I can find out.
    Edit:
    2006 Magneto 5BT-85550-01-00
    2000
    Magneto 2YG-81410-M0-00
    Looking at the tw200 main manual and the 01 and newer supplement it sure looks like the magnetos could be switched, but I guess I can't say for sure. Maybe someone who has done it will speak up.
    Senior Member Leben's Avatar
    Feb 2013
    Iowa
    264
    I agree with B-dub. You should be able to transfer your left cover and electrics as well as the magneto to the other engine. That way you can have the updated system and use your current cdi. The only other thing that is different on a pre 2001 engine is it has a manually adjusted cam chain tensioner, unlike the automatic one you currently have. I wouldn't let that stop me though, they are very easy to adjust. I adjust mine at the same time I do the valves.
  1. I need a frame
    By LittleCowTW in forum TW200 Classifieds
    Last Post: 04-24-2013, 12:31 PM
  2. 2006 TW200 3,525 miles $2000 SOLD
    By FredGarvin in forum TW200 Classifieds
    Last Post: 03-11-2013, 08:13 PM
  3. Rusty Frame
    By elime in forum General Discussion
    Last Post: 07-24-2012, 06:46 AM
  4. help with engine /frame no?
    By barley in forum Technical Help
    Last Post: 03-07-2011, 04:59 PM
  5. bent frame?
    By crossent in forum Technical Help
    Last Post: 10-12-2010, 12:22 PM
an engine that fits on the frame of a 2006 tw200
Tags for this Thread
