extended swingarm
Results 1 to 4 of 4
Like Tree2Likes
  • 2 Post By supachip1
Thread: extended swingarm
    Senior Member emilliano's Avatar
    Jan 2011
    USVI
    202
    extended swingarm
    things are VERY limited here on Island, but there are two EXCELLENT WELDERS !
    My idea, use three swingarms
    one will be for the parts , it will be cut up to use the material to make the extension
    second will be sliced and extended then powdercoated
    third will be used to make sure the finish product EXACTLY matches the width and centered (pattern)
    my "vision" is the "piece" will duplicate the pictures posted, with an inner sleeve that slides inside, until the 8" is flush at both ends
    then weld !
    anyone with suggestions please help !
    emillio
    Pleasanton, CA
    5,776
    How long of an extension do you plan to make?
    Senior Member srs713's Avatar
    Smyrna, GA, USA
    1,417
    As you describe it, there will be two points of welding on each "leg" of the final swingarm as you add 8" of material between the parts you cut.
    Here's an idea. Cut the legs of the first swingarm back near the axle holes, then second swingarm you cut 8" farther forward.
    Add the longer legs to the first swingarm, with a properly sized tubing insert at the weld joint. You will have one strong weld on each leg.
    Stephen S.
    '07 TW200:
    Apr 2013
    385
    extending the swing arm is very simple and doest require the best welder in the world…i am that proof…i did mine and it was the first thing i ever welded, cut the arm about 3" from the ends, hammer in 2x1 or 2x 1x1 metal bars inside the swing arm box section, example, if you want an 8" extend, the cut the bars at 15", hammer into the swing arm 4", then tap the ends on 2"…will leave an extension of 8"…spot weld them to secure, then finish the welds, use filler to bring to same level….took me about 2 hours to do mine and it was the first attempt and i made it up as i went…very simple
    i don't know why these picture are not in order, but you get the idea
    Fred and trktwo like this.
  1. Extended Swingarm Brake Rod Fix
    By bikerjosh in forum Performance and Customization
    Last Post: 05-06-2016, 02:18 PM
  2. Extended swingarm
    By emilliano in forum Performance and Customization
    Last Post: 08-23-2014, 01:37 PM
  3. Extended swingarm..
    By DDavis in forum TW200 Classifieds
    Last Post: 06-18-2013, 12:53 PM
  4. Extended Swingarm Advice?
    By Skullhag in forum Performance and Customization
    Last Post: 02-01-2012, 12:40 PM
  5. Extended Swingarm
    By TK200 in forum TW200 Classifieds
    Last Post: 02-06-2011, 01:44 AM
