Installing a Battery Tender Jack
Results 1 to 10 of 13
Like Tree1Likes
Thread: Installing a Battery Tender Jack
    Jun 2014
    Bel Air Maryland
    4,170
    I installed a Battery Tender Jack today. I'm not sure what that little welded on loop was used for on my bike. It sure made an excellent spot to install the connector. It's far enough away from the pipe that it doesn't burn. All the connections were soldered and wrapped with heat shrink and fused.
    Senior Member Padilen's Avatar
    May 2014
    Cadillac Michigan area
    1,598
    I'm on a cell phone so pics( but they opened) are small.
    That loop looks(?) like the one for battery vent tube. If it is you might want to check your battery vent tube routing.
    Jun 2014
    Bel Air Maryland
    4,170
    I bought my TW used off Craig's list. It had a new battery. I'll check to see if it needs a vent. I'm guessing there is some sort of nipple on the battery?
    Jun 2014
    Bel Air Maryland
    4,170
    Rats... now I have to go out and take that damn seat off again
    May 2014
    1,598
    Quote Originally Posted by TopPredator View Post
    Sorry!
    But better to know than have acid leak or worse.
    Banned ZDR1's Avatar
    Feb 2014
    Arizona
    4,030
    I see your Battery vent tube in the last photo next to the shock.
    May 2014
    1,598
    From what I can view in pic on my cell phone to me it looks just like the loop in this diagram.
    TopPredator likes this.
    Feb 2014
    Arizona
    4,030
    then mine was not installed right from the dealer I bought my bike new but it set in the showroom for over a year and the battery was dead. so I was told to come back in six hours the battery was on a slow charge. so his is vented just like mine was near the shock.
    Feb 2014
    Arizona
    4,030
    My battery vent hose was kinked and it blew the cap off so I got acid all over the bike found the hose under the battery. 10429577_10202934832723889_75955984_o.jpg I now have a sealed battery.
    May 2014
    1,598
    I bought mine used from a dealer. I posted my issues in my thread Hello best years?
    So I also had vent tube issues. Never personally had a battery blow. But couple of times I've come close, with my plow trucks. And more than a few of my friends have. Cycle battery holds less acid but it's still acid.
    I'd rather OP check and us both be wrong than right.
  1. 4 piece crutch jack
    By DonBenito in forum General Discussion
    Last Post: 11-03-2018, 12:49 PM
  2. Trail Jack
    By r80rt in forum Technical Help
    Last Post: 07-21-2013, 11:37 PM
  3. Stand or Jack?
    By nfpgasmask in forum Technical Help
    Last Post: 09-25-2012, 10:52 PM
  4. No electrical on '87 after battery tender...
    By VitaBrevis in forum Technical Help
    Last Post: 01-19-2012, 07:17 PM
