Will a modification like this hinder offroad riding, be bad for hard use?
Results 1 to 10 of 13
Like Tree2Likes
Thread: Will a modification like this hinder offroad riding, be bad for hard use?
    Junior Member Whack0's Avatar
    Sep 2014
    Colombo, Sri Lanka
    6
    Newbie to the TW world here, just thinking of buying one. I would like to use it for commuting as well as some long distance-ish rides and of course some trails if I can. Here in Sri Lanka we have many modified TWs on the market imported from Japan. Most of them have their side farings removed. Some have what seem like shorter bodies as in this link Yamaha tw 2014 For sale in Gampaha Sri Lanka wondering if experts on the forum would care to take a look at this bike and tell me what they think has been done to it, and if it in any way seriously inhibits the integrity of the bike?
    Much appreciated! and looking forward to being a part of this great community!
    Senior Member Padilen's Avatar
    May 2014
    Cadillac Michigan area
    1,598
    If you like it it's your money.
    But I'd stick closer to stock.
    As long as the engine is close to stock and jetted to match the exhaust and altitude, with a decent chain, you'll be okay for long trips, though that seat looks a little thin for long rides. The cosmetic changes won't make a difference in capability. The TW203/204 tire combo will definitely raise the paved road comfort and quiet in exchange for less traction in sand and mud. Can't see what has been done to the air filter due to the watermarks, but there needs to be one.
    Senior Member Bruce's's Avatar
    May 2014
    258
    The low pipe on a bike that doesn't have a ton of ground clearance to begin with ,will definitely hinder your off road adventures ,but I raced mx bikes with down pipes in the mid 70's so it might be just fine for you .If you can get the stock parts with it you can swap back and forth easily if you like .
    Sep 2014
    Colombo, Sri Lanka
    6
    Thanks guys! Yes, getting the stock parts won't be that hard. Just wondering if this bike has been sorta altered beyond hope
    Also another important question I had; is there a way you can clearly tell the difference between pre and post 2001 models other than the disk brake and kickstarter? (because a lot of them are retrofitted here)
    May 2014
    258
    Serial number will have the answers ,as long as they have not been altered
    Sep 2014
    Colombo, Sri Lanka
    6
    Thanks Bruce! I don't think they'll be altered. care to elaborate on the exact differences in serial number involved? Be very grateful
    Different serial number formats are required in different markets. You'll need to research that locally.
    Sep 2014
    Colombo, Sri Lanka
    6
    thanks!
    Apr 2013
    385
    it looks a bit too worn to be a 2014, i would say its a good few years older. there are a few tw's on there that are older than the year advertised,
    this bike has a standard rear end, some of the other tw's listed on that site you can see have extended swing arms which give the bike a longer look.
    i don't understand the Japan frame numbers, and cannot find the info online, my bikes have 9 digits rather than 17, there is a thread on here about this titled...9 digit VIN number on bike, confused
    i have found so far that regarding the years,(from sitting on the bike) pre 00 older models the throttle cables attach to the carb on the left side, and right side on newer models 01 up, there is also a metal loop right side on the later models frames (just below the tank) for these cables to pass through but cannot see in the pictures.
  1. My current trail/offroad/adventure riding
    By pbeezy in forum Trails, Off-road, and Adventure Riding
    Last Post: 08-23-2014, 09:23 PM
  2. air filter modification - help
    By tokey in forum Performance and Customization
    Last Post: 06-06-2014, 06:47 AM
  3. Dual Headlight Modification
    By r_marsh in forum Performance and Customization
    Last Post: 03-13-2014, 03:57 PM
  4. Muguard modification
    By Sly Fox in forum Performance and Customization
    Last Post: 04-03-2011, 12:18 PM
  5. stock muffler modification
    By tripleted in forum Performance and Customization
    Last Post: 03-09-2011, 08:10 PM
Tags for this Thread
