Longer control cables?
Results 1 to 5 of 5
    Senior Member Trikstr's Avatar
    Jun 2012
    Oak City, UT
    156
    Between the franken forks and the XT350 gas tank I need to put longer cables on my '99. Lizdrbrth(the man) posted once that XT225 cables(speedo/brake) would fit and give you 3" more length. Anyone here tried them?
    If so how did they work out? Any part #'s or years that interchange.
    I'll start researching exploded drawings to see what I can come up with.
    TIA
    '99 TW,Ricochet skid plate, Seat Concepts, Jimbo shield, 2" extended swingarm w/Maxxis Bighorn, 5.10 Kenda K270, Stealth exhuast, YZ80 hybrid front forks w/HyperPro proressive springs, ProCycle high mount front fender, ProCycle wide foot pegs, TT-R stainless head pipe, Lizrdbrth cooler, D-Flex hand guards, XT350 gas tank.
    2002 Honda Spirit Shadow VT750
    1987 BW350
    '78 Honda XL100
    Jun 2012
    Oak City, UT
    156
    Stadiums' page is loading slowly today. But what I found so far is XT's(225/350) & TTR's all have disc front brakes. Clutch and Speedo cables appear to have same ends. Our local Yamaha dealership burnt to the ground last fall. Wish there was one closer than 60 miles that had a big enough inventory to actually look at some parts.
    1987 BW350
    '78 Honda XL100
    Jun 2012
    Oak City, UT
    156
    Looks like maybe the one's from an '80 XT250 will work. I'll have to call Stadium Yamaha. They list the part #'s on their web page.
    1987 BW350
    '78 Honda XL100
    Jun 2011
    AZ
    793
    I got mine in Japan. I am sure Webbike has it? If its too much then find a quality motorcycle shop. They can build one from scratch to exact sizes. Have them build a extra one just in case you are adventuring and the unspeakable happens and this way you don't get stuck in the middle of no where.
    Jun 2012
    Oak City, UT
    156
    Thank you very much!
    1987 BW350
    '78 Honda XL100
  1. Sensible Gun Control!
    By GaryL in forum Off-Topic
    Last Post: 06-04-2014, 12:04 PM
  2. Rear shock modification for control/comfort
    By Gerry in forum Performance and Customization
    Last Post: 09-01-2013, 06:45 AM
  3. Aftermarket Control Levers
    By Knightowl in forum Performance and Customization
    Last Post: 04-01-2012, 06:21 PM
  4. longer cables?
    By Rhodetrip in forum Technical Help
    Last Post: 09-21-2011, 09:03 PM
  5. cruise control
    By mrmagoo in forum General Discussion
    Last Post: 08-12-2010, 12:23 PM
