Brake Lever for shorter reach
Results 1 to 10 of 15
    Junior Member RonnieGasoline's Avatar
    Oct 2014
    1
    I'm trying to find an aftermarket brake lever designed for smaller hands for a 2014 TW. Does anyone know of a company that makes them ...or a lever from a different bike that would work? (I tried ASV's adjustable lever but it doesn't fit correctly)
    Jun 2011
    AZ
    793
    I was searching around. I don't know how small your reach is if a ASV isn't working.. You might have modify the stock or modify another one.
    Pleasanton, CA
    5,777
    Welcome to the forum Ronnie!
    Maybe I could trade you my custom bent lever for your stock one !
    Seriously, you can reduce the reach some by using the adjustment screw or you could try bending the lever to change the curve to bring it in closer to the hand grip. I'd suggest having a spare lever on hand before trying to bend yours. Sometimes they will bend and sometimes they just break. Also, be careful not to bring it in so close that you bottom out against the grip before reaching maximum braking.
    Brian
    Senior Member Padilen's Avatar
    May 2014
    Cadillac Michigan area
    1,598
    They use to make plastic levers that turned in. I still have one in my box of stuff.
    I can look tomorrow, and post pic. If you'd like, then just PM me.
    May 2014
    1,598
    Here's what I have.
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,305
    The shortie is plastic? Do you remember who makes it? I would love to find a shortie that fits without spending big $$ on ASV levers...
    May 2014
    1,598
    Sun Line is molded in the end.
    I didn't try it to see if it would fit but they fit all my other Yamaha's. I have no idea why I don't have clutch levers. Might have "loaned" them out.
    rbm
    rbm is offline
    Jan 2011
    4,305
    Do you have any receipts, part numbers?
    Senior Member Werloc's Avatar
    Nov 2013
    Central, NJ
    1,983
    Bob
    When in doubt, Gas It..!!!
    May 2014
    1,598
    No, their from my box of scrap parts from my 1978 DT250 and 1981 IT175 and 1984 IT200.
    If OP doesn't want it you can have it.
  1. Front brake cable/lever?
    Last Post: 11-09-2012, 03:37 PM
  2. Front brake cable/lever?
    Last Post: 11-09-2012, 02:48 PM
  3. Hard front brake lever
    Last Post: 02-25-2012, 11:32 AM
  4. Rear Brake Lever
    By FnMag in forum Technical Help
    Last Post: 12-20-2011, 01:43 PM
  5. front brake lever
    By RisingSun in forum Technical Help
    Last Post: 10-11-2011, 02:18 PM
