Absolutely the Easiest TW Modification Ever!
Results 1 to 7 of 7
Like Tree6Likes
  • 3 Post By TW-Brian
  • 1 Post By Fred
  • 2 Post By Mel
Thread: Absolutely the Easiest TW Modification Ever!
    Pleasanton, CA
    5,682
    Just install one or two binder clips as shown below:
    These are handy for holding trails maps, bridge tolls, etc.
    I have personally tested these at triple digit speeds (in kilometers per hour !) and they have never failed.
    HermanJohn, Rhodetrip and admiral like this.
    Senior Member Mud Dog's Avatar
    Feb 2015
    East London, South Africa
    281
    Thanks for sewing doubt in my mind ... I was planning on throwing that little fairing off and replacing the headlamp / speedo / warning indicator array with something more retro! LOL!
    18,593
    I don't know, looks terribly expensive Brian, and will they fit a 2003?
    Plus, do I need to change suspension settings due to additional downforce they will generate at triple digit speeds?
    Before I added my Jimbo shield I found that our standard size folded Forest Service maps fit perfectly without need for restraint even on my easy trails. Now I'll try your clips. Thanks.
    TWilight likes this.
    1,110
    I have a handful of those clips in every vehicle, mostly to close partially eaten bags of stuff. Never thought about using them there though. Thanks Brian, good idea.
    Mel
    Mel is offline
    Senior Member Mel's Avatar
    Jan 2013
    San Luis Obispo, Calif.
    1,174
    Those clips are ideal for holding the seat covering in place before stapling. Allows stretching and frees you hands.
    Mel
    Fred and TWilight like this.
    Senior Member harvey's Avatar
    Aug 2012
    Grose Wold NSW Australia
    124
    Great idea I do like the silver TDUB badge are they available ?
    Boys and there toys.
    HondaZ50ak2 , Honda CT70 , Honda ST50 , Suzuki TC120 , Suzuki LTF400 , Nissan Navara D40 , XT225 , 2006 + 1993 & 1989 TW200s. Hidden Content
    Pleasanton, CA
    5,682
    Quote Originally Posted by harvey View Post
    Yep, that pin is the fine work of our fellow forum member Rhodetrip.
    PM him and he'll fix you up with one.
  1. Replies: 20
    Last Post: 01-14-2015, 08:12 PM
  2. Easiest carb access
    By GIFUTW in forum Technical Help
    Last Post: 02-25-2014, 09:51 PM
  3. Best/Easiest engine swap? Looking for more power!
    By BattleKing2Delta in forum Performance and Customization
    Last Post: 12-05-2013, 10:09 PM
  4. 1987 TW200 - Absolutely no response to throttle at all
    By craig0ry in forum Technical Help
    Last Post: 11-11-2013, 06:02 PM
  5. Easiest way to get this 1994 TW200 going (bent valve)
    By JTpowersports in forum Technical Help
    Last Post: 06-03-2013, 01:10 PM
