Finally got around on changing the rear spring for Moab.
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Like Tree15Likes
Thread: Finally got around on changing the rear spring for Moab.
    Banned ZDR1's Avatar
    Feb 2014
    Arizona
    4,030
    Finally got around to changing the rear spring for Moab.
    Finally got around to changing the rear spring for Moab. 11008935_10204830889324119_585679126_n.jpg I did not remove the rear tire but if I did it again I would. and I found a good use for my cutoff tool disk changing wrench. 11003186_10204830889044112_37248839_o.jpg 10998175_10204830887564075_340727003_o.jpg
    GTG likes this.
    Feb 2014
    Arizona
    4,030
    And FedEx dropped this off . 10999217_10204831092329194_1661595943_o.jpg spare for Moab.
    Senior Member Hekkler's Avatar
    Jun 2014
    Tacoma Washington
    485
    I removed my rear tire and it made a big difference, but did you remove your tank? On mine the upper mount bolt would not bypass a very small piece of the tank seam or flange. Instead of pulling the tank I just used a dremel tool and removed about 1/8" of material to get the bolt out all the way. Made it much easier.
    Senior Member Werloc's Avatar
    Nov 2013
    Central, NJ
    1,983
    Hm, I had my shock in and out 6 times. All I removed was seat, and just lifted the rear end of tank enough for top bolt to clear. Shock goes in and out from the top and with some wiggle'n, the bottom. First time took a few minutes to figure it out. I hate doing extra work.....
    PlacerLode likes this.
    Bob
    When in doubt, Gas It..!!!
    Feb 2014
    Arizona
    4,030
    Quote Originally Posted by Werloc View Post
    I did it how the TW service manual showed how to do it. I do not see a reason to remove it again, now I need to stiffen up the front.
    Feb 2014
    Arizona
    4,030
    Quote Originally Posted by Hekkler View Post
    I have the Clarke tank and just took out the bolt and lifted it some.
    Pleasanton, CA
    5,822
    Quote Originally Posted by zdiver1 View Post
    Here's what I did to stiffen up the forks on mine:
    -Cut two 3/4" long pieces of PVC pipe. (I used some gray 3/4" ID x 1" OD plastic conduit that I had laying around)
    -Lift the front end of the bike so the front wheel is off the ground.
    -Doing one fork leg at a time, loosen the top triple clamp and remove the top fork cap. Insert one of the PVC spacers on top of the existing metal spacer. Apply downward pressure on the fork cap to compress the spacer/spring enough to get the fork cap started. Re-tighten fork cap and top triple clamp.
    -Repeat process on the other fork leg.
    Two days ago on Joemama's ride we did about 75 miles off-road which included some pretty deep ruts and rocky water crossings. I was only able to bottom the front end once. Without the added spacers, I probably would have bottomed the front end at least a dozen times.
    This is a really easy mod.
    ZDR1, TWilight and PlacerLode like this.
    19,158
    Nice tip Brian. My wife's cooking somehow prevents me from dropping 10 lbs so maybe I could benefit from stiffer front end @ my current 190lbs. However I would hate to sacrifice the suppleness I enjoy while slowly navigating boulder strewn Sierra Jeep trails. As Paul's Moab Roomie perhaps we can swap bikes for a mile or two so i can appreciate a firmer suspension while he experiences ATV tire traction.
    ZDR1 likes this.
    Senior Member cccan's Avatar
    Sep 2013
    Edmonton, Alberta
    193
    I gotta ask...what do you guys weigh that you have to change the suspension........I am a svelte 225 should I be changing mine out? or just pushing my self away from the table..
    Feb 2014
    Arizona
    4,030
    I found this also. Stiffeninerup
    After scouring the FORUM for info on fork tuning I decided to forego spending $300 on the beef up kit and take Mr. Brth's advice...
    1) Rig bike into Crouching Dog position so that forks are plumb vertical.
    2) Move handlebars to clear the way for fork guts removal.
    3) Remove fork caps, extract stock spacer tubes, fabricate long hook from coat hanger and extricate springs.
    4) Fully compress forks and measure distance from top of tube to top of fork oil. I was shocked to find 150mm from the factory since their spec calls for 135mm. No wonder I had been getting such an adrenaline rush from front wheel braking.
    5) Being the lazy type I chose to extrapolate a guess, with Lzrd's "It"s Done" post as my basis, that 130mm would get me in the ball park to support my 285 lb. carcass. Added 10 wt. fork oil to attain desired level in each tube.
    6) Fabricated new spacers from 3/4" PVC pipe, 3/4" longer than stockers and reassembled per the recipe. Condition of oil and innards was pristine with no signs of moisture (2001 Model).
    SHAZAMMM! The results are almost unbelieveable.Thanks to the TW 200 Forum for sharing the LOVE.
    Suspension now feels very nice and sag is now 1.5".
    This took 1 hour since I did not remove the forks from the bike and cost $7.50.
    •Share
    Fred and PlacerLode like this.
  1. Back to moab in the spring 2015
    By Roninboise in forum Trails, Off-road, and Adventure Riding
    Last Post: 03-29-2015, 06:43 AM
  2. Rear spring
    By ZDR1 in forum Performance and Customization
    Last Post: 12-30-2014, 08:45 AM
  3. FS: rear shock/spring $25
    By evan in forum TW200 Classifieds
    Last Post: 05-07-2014, 01:17 PM
  4. Does anyone have a picture of the 1/4" rear spring spacer?
    By blackmouthcur in forum Performance and Customization
    Last Post: 02-14-2014, 05:28 PM
  5. Southern Utah Spring 2013 Adventure Ride Moab
    Last Post: 04-25-2013, 08:11 PM
19kgmm spring tw200
spring spacer
