Base jetting vm28-418
Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Like Tree6Likes
Thread: Base jetting vm28-418
    Member Jd87's Avatar
    Aug 2014
    34
    Can anyone tell me where to start for jetting a vm28-418 for my 02 tw200? I've searched and couldn't come up with anything. I want to order everything one one shot. And before I order are there any other direct replacement carbs for the tk to consider? Or is the vm-28 the best option? Below is the one I will be ordering.
    http://www.amazon.com/Mikuni-Series-.../dp/B000GZO5EG
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,392
    Sebastian (MacBig) is the only one that I am aware of that is using the VM28, and his bike is not a stock TW200.
    He has posted that it is not a easy carb to get properly tuned.
    Perhaps he will soon post about it.
    An alternative carb is one of the Chinese copies of of the Mikuni VM24/26, listed on eBay as a BW200 carb.
    The carb will work (I have tried one on my TW). However, you will need to modify the carb screw-on top, where the throttle cable connects.
    Or better yet, make a custom throttle cable, so you don't need to mod the carb top.
    Either way you will need a different cable, and perhaps a different throttle control. The stock throttle cables are in a push-pull configuration, and the VM28 is a single pull cable, which has a different lug on the carb end.
    The Chinese carb is also shorter from front to back so the air box boot is too short. Another forum member has solved the problem using duct tape.
    If you bike is a pre-2001, you will also need a separate start/kill switch.
    Jb
    18,587
    Have you searched archives here, specifically those of PalmStateCrawler and MR.Bracket? They have both been down the road of all that is involved with the care and feeding of the Mikuni VM28-418 in a TW application and have reported here in depth. Somewhere in those depths I seem to recall baseline jetting numbers. I seem to recall a bit of modifications were required and the resulting performance was never good enough to sweep the world by storm.
    To bad as I drooled over idea of crisper throttle response of the pumper carb option but Mr.Bracket couldn't get sufficient performance out of that one either it to make a conversion kit for TWs.
    You could start here, although I think PalmSrateCrawler sold his bike and moved on.Jets for mikuni tm28-1 and vm28 for sale
    FL. GA, NC
    2,392
    Fred, didn't Mr. Bracket and Palm State Crawler use the TM, a pumper carb?
    The VM is not a pumper carb.
    Jb
    FL. GA, NC
    2,392
    Well, there may be a bit of confusion on my part.
    I checked the Mikuni catalog, and the VM carbs are all listed as "round slide" carbs. All except for the VM28-418 which is listed along with the "flat side" TM carbs....?
    ...waiting for MacBig or Mr. Bracket to clarify.
    jb
    18,587
    Escuse me, I was referring to the TM28-1 not the VM28-418 ,as the Mikuni pumper that Mr.Bracket and PalmState Crawler also experimented with unsuccessfully; discussions for both conversions were part of the referenced postings by both authors if I recall correctly. Either way neither Mikuni was deemed a perfect upgrade for everyday use.
    Dryden-Tdub likes this.
    Apr 2014
    Dryden NY
    6,336
    Fred, you are getting old and forgetful. How could you recall so poorly!?
    Oh dear. I have been bad again....... Who will you have punish me this time Fred?
    I will be waiting patiently with a glass of wine and some lotion
    Tom
    FL. GA, NC
    2,392
    Here's the carb Mr. B used:
    https://tw200forum.com/forum/performa...html#post56577
    Apparently, the VM28 is part of the TM series of the Mikuni flat slide carbs...really confusing to me.
    The link provided by the JD87 shows the carb listed as both a TM and a VM.
    IMO.., a better choice for for a stock TW200 would be the Mikuni VM24 or VM26 round slide carb.
    Those are the ones that the Chinese clones are copied from, and we know the Chinese carb will work, with modifications to the throttle and cable, and the boot to the air box.
    jb
    FL. GA, NC
    2,392
    Interesting enough is one of the Amazon reviews on the OP's link:
    Amazon.com: BIGFOOT's review of Mikuni TM Series Flat Slide Carburetor (VM...
    ...wonder how Bigfoot got it to work.
    jb
    18,587
    I got really confused with various posts referring to two different carbs and designations, sorry. But to quote MrBracket in his build post #390
    "Yes, it's a Mikuni TM28 (aka:VM28-418) It is a 28mm Flat slide carb that is very similar to the ones found on 1980-1990's Suzuki RM80's"
    Yet PalmStateCrawler's classified add seems to depict and refer to two different carburetors. Odd. Jets for mikuni tm28-1 and vm28 for sale
    I'll back out now and let Original Posters clarify things, was just trying to help.
    If indeed Jd's carb is the same as MrBrackets as depicted in posts around #390 he might find the jetting answers he seeks starting around post #340.
    Remember carb says "Not For Aircraft" so be careful how high you get that hot rodded TW flying after she's all jetted up.
    P.S. BIGFOOT could be contacted via his Amazon.com sales site for details
  1. Re-jetting
    By r_marsh in forum Performance and Customization
    Last Post: 06-05-2014, 11:13 AM
  2. Jets for mikuni tm28-1 and vm28 for sale
    By PalmStateCrawler in forum TW200 Classifieds
    Last Post: 10-16-2013, 12:31 AM
  3. Jetting for maintenance
    By Adam-n-nevada in forum Technical Help
    Last Post: 11-02-2012, 07:53 PM
  4. Jetting Tip - Too rich
    By len in forum Performance and Customization
    Last Post: 08-08-2012, 09:55 PM
  5. Jetting for 10k feet
    By -Jake- in forum Performance and Customization
    Last Post: 08-07-2012, 05:04 PM
chinese clone tw200
mikuni tm28
mikuni tm28 clone
mikuni vm28
mikuni vm28-418
mikuni vm28-418 tw200
teikei tk round slide tw200
tw200 mikuni
tw200 mikuni carb vm28
tw200 mikuni vm26 swap
tw200 mikuni vm28-418 upgrade
tw200 with mikuni tm28
