*Prototype* Quick Release (change) Storage Box
Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By nunya
Thread: *Prototype* Quick Release (change) Storage Box
    Senior Member nunya's Avatar
    Sep 2014
    Elberta, AL
    251
    So I was trying to find a use for these ---> QL-25 S Quik-Latch Mini Latch Fastener
    And had seen a storage box thread, can't remember where now, where someone had a pelican-type case with 3 screw downs on the inside.
    So I tried this with my not-so-infamous bright orange storage box that was once held on with three u-bolts.
    So I put 3 mini latches in the bottom...
    Installed the pins they latch to on here....
    .....and I don't have a pic with it on the bike but you smarties can figure that out.
    So my plan in the future once i get to miami, is find a metal shop that can weld a plate on the underside of the rack covering all the open areas, even the small areas on the forward sides of the rack. Strategically place a series of holes within said plate so I can configure as necessary. All this so I can switch out different types of boxes with minimal effort. Looking to get a low height pelican type case, just to hold tools and smallish type stuff and then have on hand, a larger (deeper) box, for grocery-getting or bigger stuff.
    Its easy to operate, just press the center button to release, the button remains depressed (not in the sad, suicidal sense), and the box lifts right off. Installing, just line up and place a little pressure around each latch until it clicks. This box I have is currently really flimsy, which is fine for the time being, but it does flex while installed. A more rigid box will do better.
    A couple of considerations though, should anyone decide to go this route. I don't know how much stress these latches can withstand before they break. So if you had a rigid pelican case, say, 16x14x9, carrying a bunch of tools or something weighty and you hit a pothole and it bounced around enough, if the latches would give out....not sure. Also, Ill need to find plastic caps for the underside of the latches, so when not in use they are not getting wrecked.
    I have considered using these as a seat quick release system and could work, but will require some modification to the current mounting system on the frame of the bike. I have neither the tools nor the skills to do that, so I may do that at another time.
    Fred likes this.
    18,585
    Someone here in the last week or so posted a link to an electronics store that had nice rigid boxes like Pelicans but at more affordable prices. Somehow I lost the link I had hoped to share with you. Can anyone help re-locate this post?
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,300
    MCM Electronics, the brand is DuraTool.
  1. quick release seat bolts
    By joeband in forum Performance and Customization
    Last Post: 04-17-2015, 02:01 PM
  2. Replies: 0
    Last Post: 07-05-2014, 09:03 PM
  3. Quick release bolts for seat
    By williamemack in forum Technical Help
    Last Post: 09-15-2013, 07:13 PM
  4. first oil change, quick question
    By russ5415 in forum Technical Help
    Last Post: 02-13-2013, 10:25 PM
  5. Moose Racing Quick Release Chainsaw Bracket on Rear CycleRack
    By flingwing1969 in forum Performance and Customization
    Last Post: 08-11-2012, 05:49 PM
