Adding Lights To The HF Motorcycle Rack
Results 1 to 8 of 8
Like Tree6Likes
  • 3 Post By TopPredator
  • 1 Post By Dryden-Tdub
  • 1 Post By Werloc
  • 1 Post By TopPredator
Thread: Adding Lights To The HF Motorcycle Rack
    Jun 2014
    Bel Air Maryland
    4,169
    I originally bought the HF Magnetic Towing Light Kit. I found to be cumbersome to use every time I hauled my TW. I started searching for a solution that met my needs and allowed me to utilize all the adjustments available on the rack. I wanted LED lights that would be heavy duty, waterproof and small enough that they didn't protrude above or below the width of the rack. I searched all the available options and none of the Stop/Turn Tail Lights allowed this. One of my favorite trailer parts stores is EasternMarine.com located in Delaware. While on a trip North one day last year I stopped in to see if they offered lights that would fit my application. I bought four single, two wire "hot/ground" LED lights and they are perfect. I build a Mock-up to ensure the proper operation of the lights I finished the installation and I'm completely satisfied with how well it turned out. If anyone is interested in duplicating this I can provide more tips and measurement details.
    Parts Needed:
    B-Optronics Light MCL13 p/n 1294101
    # 6 X 5/8 Pan Head Phillips sheet metal screws needed for mounting the lights
    # 6 X 1/2 Self Drilling Screws for the Cable Clamps Heat Shrink, Solder, Trailer Wire, 4 Flat Connector, 1/4 and 3/8 Cable Clamps.
    If I知 ever on LIFE SUPPORT, UNPLUG ME. Then plug me back in... See if that works. Hidden Content
    TW 2006 Ruth
    TW 1988 Black Widow.
    1994 Harley FXR
    Rick
    Apr 2014
    Dryden NY
    6,336
    Very professional looking build Top. What was your total out of pocket cost on this project?
    Tom
    TopPredator likes this.
    Senior Member Werloc's Avatar
    Nov 2013
    Central, NJ
    1,983
    Looks good Rick. As soon as my bike is done in the next day or 2, I will be doing mine. My wife bought me a cheap set from Walmart for Christmas since that's what I wanted being on a very tight budget. Later this week I should finally get around to do it. I'd like to have it done in time for the 2 day PA ride coming up on the 28th and 29th. Something is better than nothing.
    Bob
    When in doubt, Gas It..!!!
    18,603
    Very nicely done Top, those should be very good at resisting any accidental damage.
    2006 TW200 "Nibbler", a.k.a. 溺r.Gizmo"
    Hidden Content All Things Considered I値d Rather Be Motorcycling
    Nice to see you're concerned with safety. I shudder at some of the nightmares Is on the road.
    Tdub has a trailer plug under her box that was originally used for a trailer she pulled, but a jumper from the trailer lights activate all her clearance, stop, and tail lights in odd ways that serve as real attention getters when she is on the trailer.
    Jun 2014
    Bel Air Maryland
    4,169
    Quote Originally Posted by Dryden-Tdub View Post
    Tom
    Lights X4. $5.86 each Eastern Marine
    Screws. $4.00. Home Depot.
    Cable Clamps $3.60. Home Depot
    Wire. $ 15. Walmart. Used 1/3
    4 flat connector. $3.50. Walmart
    Heat Shrink ? Stock
    Self Start screws ? Stock
    I also had the spirit cable wrap in stock that I used to wrap the lead wires to the 4 flat connector. It's a hard plastic spiral wrap that I bought years ago. Goes for about $10 for 33 ft Amazon. I also used this wrap when I installed my 12v outlet on my TW
    Dryden-Tdub likes this.
    TW 2006 Ruth
    1994 Harley FXR
    Rick
    Jun 2014
    Bel Air Maryland
    4,169
    Very cool idea simple and effective.
    TW 2006 Ruth
    1994 Harley FXR
    Rick
    Jun 2014
    Bel Air Maryland
    4,169
    Check the bolts on your HF Rack mine needed tightening up after one season.
    TW 2006 Ruth
    1994 Harley FXR
    Rick
  1. Motorcycle Carrier Brake lights.
    By ZDR1 in forum General Discussion
    Last Post: 03-06-2016, 02:30 PM
  2. adding a Rev counter and better Lights
    By dubstep in forum General Discussion
    Last Post: 02-07-2015, 01:53 PM
  3. Adding LED lights to front rack?
    By boznarras in forum Performance and Customization
    Last Post: 12-23-2014, 02:16 PM
  4. Motorcycle trailer lights
    By n2o2diver in forum Technical Help
    Last Post: 05-16-2012, 09:41 AM
  5. adding extra lights
    By dubstep in forum Technical Help
    Last Post: 11-09-2011, 08:39 AM
