13 tooth front countershaft sprocket.
Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Like Tree12Likes
Thread: 13 tooth front countershaft sprocket.
    Member ShaggyAnt's Avatar
    Mar 2015
    North Idaho
    50
    While I'm busy working up to blowing up my second Duro Powergrip I ordered a 13 tooth countershaft sprocket. Does anyone else have one of these or is it even a good idea?
    My bike already came with a 54 tooth rear sprocket so I can't see spending money on a 55 tooth. Will it be ok with a 13 and a 54?
    Apr 2014
    Dryden NY
    6,336
    Quote Originally Posted by ShaggyAnt View Post
    should be able to pull up tree roots with that tire and gearing!
    Tom
    18,578
    ShaggyAnt, that is the set-up I have with my Duro, 13 in front, 55 in the rear. Due to Duro's significantly larger diameter this is not really ridiculously under geared. As Tom hints, it does give the Power to Grip darn near everything. I max out at about 63 mph but it is much happier at 55 or less. I consider the gearing correct for the intended use...trail riding in challenging terrain.
    Mar 2015
    North Idaho
    50
    I'm not really too interested in top speed. I wouldn't have bought a TW200 if I was . If I can hold 45 mph I will be fine with that. My biggest concern is climbing the steep terrain we have around here. I like to ride the fire roads but single track and hill climbs are really where it's at for me.
    18,578
    You should be happy with the 13/55 combo then; enough torque in second gear to take advantage of the traction afforded by the ATV tire yet with a low first gear to fall back on for the truly nasties. Where do you hail from Shaggyant? Last Duro fan I met rode primarily in muddy conditions with much taller gearing but I prefer your intended set-up despite the reduced service life of the tiny 13 tooth front sprocket.
    Senior Member Trikstr's Avatar
    Jun 2012
    Oak City, UT
    156
    I've been running 13 tooth s since mid 90's on 2 of the 3 TW's I've had. On my 99 13/54 with Bighorn 35 sounds happy.
    '99 TW,Ricochet skid plate, Seat Concepts, Jimbo shield, 2" extended swingarm w/Maxxis Bighorn, 5.10 Kenda K270, Stealth exhuast, YZ80 hybrid front forks w/HyperPro proressive springs, ProCycle high mount front fender, ProCycle wide foot pegs, TT-R stainless head pipe, Lizrdbrth cooler, D-Flex hand guards, XT350 gas tank.
    2002 Honda Spirit Shadow VT750
    1987 BW350
    '78 Honda XL100
    Senior Member Borneo's Avatar
    Feb 2014
    6,368
    Fred knows of what he speaks, I've seen him ride. Of course I also got to see him not ride, but that had nothing to do with his tire and gearing.
    admiral likes this.
    my blog Hidden Content
    Mar 2015
    North Idaho
    50
    I updated my location. Ever heard of the Ruby Ridge standoff from back in 1992? I'm just an bit south of there in North Idaho.
    18,578
    Well, you certainly live in Duro country then.
    Hope that rascal pops on soon so you can enjoy it and the fun that comes with 13/55 in steep terrain. Must be getting prime riding conditions with trails melting out and winter deadfalls to be negotiated. Once upon a time I worked and rode a bit NW of Upper Priest Lake in the mtns. where the Air Force ran one of it's Escape and Evasion survival courses. ( now called SERE, Survival Evasion, Resistance and Escape). Nice country.
    Good luck.
    Mar 2015
    North Idaho
    50
    SERE is over at Fairchild still. A guy I know teaches some of the classes. Were you ever out at the research center on Ponderay in Bayview? Know a couple of guys up there too.
    Edit: Woo Hooo!!!!!! I just let the air out, re-lubed with KY and 90% isopropyl alcohol. Then I put the chuck back on and sent her up to 95psi and she popped right on like it was nothing. Awesome!!!!! I'm going to try and get ahold of the other guys who left three hours ago and get up on that mountian to try this beast out.
  1. 50 tooth to 47 tooth sprocket question
    By Little General in forum Technical Help
    Last Post: 07-05-2018, 10:26 PM
  2. Countershaft sprocket
    By Yan in forum Technical Help
    Last Post: 08-20-2014, 10:57 AM
  3. 15 tooth front sprocket vendors?
    By Matt in forum Performance and Customization
    Last Post: 07-09-2012, 10:44 AM
  4. Replies: 0
  5. tips to getting inner countershaft sprocket seal out?
    By triple3jrb in forum Technical Help
    Last Post: 02-21-2012, 03:53 PM
countershaft sprocket 1 tooth wqals 6 mph
tw200 13 counter shafe sprocket
