USB charging port
Results 1 to 5 of 5
Like Tree11Likes
  • 9 Post By Rhodetrip
  • 1 Post By Smitty Blackstone
  • 1 Post By Ski Pro 3
Thread: USB charging port
    Senior Member Rhodetrip's Avatar
    Aug 2010
    Out wandering around
    1,930
    USB charging port
    I used to have a 12 volt socket with a usb converter in it that I would use to charge my phone. It was OK for that, but it did not put out enough of a charge to power my tablet. So I was looking for an alternative. I bought a couple of Tusk 2 usb plugs, and they were pretty good but kind of large and I decided not to use them.
    Then I bought a new Garmin Montana gps. My old 60cx was powered from the bike with a dedicated cord that plugged into it. One of the good things with the Montana is that it has a powered, LOCKING mount.
    But then I realized that the mount required direct wiring to the bike, so I would not be able to swap the mount between bikes. Bummer.
    I came across a thread on ADVrider. Someone used a sae plug from a batterytender to power the mount. Bingo. This is what I did.
    I got a few battery tender pigtails, and bought some fairly heavy lamp cord to minimize the volt loss with the added length.
    I cut and spliced the pieces. Soldered and double shrinked the staggered joints. Ended up making it 56 inches long
    I then removed the battery tender pigtail and the Gps charge cord that I had and replaced them with the new, longer cord. I ran it up to the dash area and left a bit at the end.
    Rewired the Gps mount with an Sae plug. But I also got 2 Deltran Battery Tender accessories. The Gps has a rechargeable battery, so I can run it disconnected for a while.
    Then I can charge my phone with the USB plug. It also puts out a higher charge so my tablet will charge too.
    I also can plug in the Voltage meter ( I also did the same on Lynn's bike so she can check her charge status while she's running both her heated grips and her auxiliary lights at the same time !!)
    Its also a good, accessible point to connect the battery charger when I use that. The only downside, as Fred pointed out, is that the volt meter does not work with lithium batteries.
    I have Shorai batteries in 2 of our bikes- so the voltmeter won't work with them. The 2 I have in RI still have wet cell batteries so those can use it. I'm pretty pleased with the result because it removed a bunch of things connected to the battery, and still powers all my stuff.
    "Me and Mrs Trip, we got a thing going on"... an on-going adventure...
    "When Piggies Fly" ...Me & Mrs Trip Cross the Pond
    "Take the Puppy to the Beach"...a dirt route across southern New England
    Latest Spotwalla: Hidden Content
    Sep 2014
    Mamaroneck, NY
    2,176
    I use the Battery Tender voltmeter to test all of my bikes. It works with lithium batteries.
    Darth likes this.
    May 2014
    Yooper, MI
    1,506
    I think that lithium battery will be my next up grade.
    Can you really notice the weight savings?
    EWB
    EWB is offline
    Senior Member EWB's Avatar
    Oct 2015
    Campbell, CA
    674
    Quote Originally Posted by Devils Advocate View Post
    Yeah that's on my list too
    Senior Member Ski Pro 3's Avatar
    May 2014
    El Dorado, California
    797
    I have the Battery Tender BTL14A240C Lithium Iron Phosphate Battery. It's the next size up from what Battery Tender says will fit. It's a tight fit, but I think that's better! They weigh next to nothing.
    I got mine off Amazon for $90 November 2014, but I see they are a little higher now;
    Amazon.com: Battery Tender BTL14A240C Lithium Iron Phosphate Battery: Automotive
    Fred likes this.
    The bear slayer!
  1. Port Angeles, WA to Miami, FL
    By nunya in forum Trails, Off-road, and Adventure Riding
    Last Post: 03-19-2015, 08:24 PM
  2. Carbon on exhaust port
    By cololevi in forum Technical Help
    Last Post: 09-15-2014, 09:55 PM
  3. That Vacuum Port....
    By Tom Bettiker in forum Technical Help
    Last Post: 01-13-2014, 06:29 PM
  4. Replies: 9
    Last Post: 07-18-2012, 08:20 PM
  5. TW not charging?
    Last Post: 06-25-2012, 09:52 PM
advrider phone charger problems
yamaha tw200 usb hookup
