Like my battery disconnect?
Results 1 to 9 of 9
Like Tree8Likes
  • 4 Post By acjlarsen
  • 2 Post By WECSOG
  • 1 Post By scotti158
  • 1 Post By JustPassinThru
Thread: Like my battery disconnect?
    Member acjlarsen's Avatar
    Oct 2011
    35
    Ive had problems for years kills batteries. Ive come to realize that there must be a small short in the wiring harness somewhere. I was faced with two options, either tear apart the wiring looking for a short, or wire a disconnect in. I had trolling motor wire and high quality plugs lying around and patcher her together.
    Sent from the first city on the Mississippi.
    Senior Member WECSOG's Avatar
    Jun 2015
    2,417 miles from LT! ;-]
    742
    Man, that's as redneck as it comes, right there!
    I like it!
    18,729
    I like it. We could critique it and suggest solutions and improvements but if it works congratulations. I enjoy creative solutions to vexing problems.
    Oct 2011
    35
    Lets hear your fancy solution
    May 2013
    Groton, NY
    2,663
    Your slow drain is probably the rectifier, unless you have some aftermarket accessory draining the battery.
    Smitty Blackstone likes this.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    Oct 2011
    35
    No accessories. What's the rectifier do?
    Senior Member JustPassinThru's Avatar
    May 2015
    762
    The winning solution...costs little money; less time; gets you back on the road fast.
    It reminds me of a problem I had with an intermittent relay partial-failure I had on a Yugo...removing the battery cable reset the relay, for days or weeks until it happened again.
    But that could be inconvenient in the middle of a busy intersection. After a couple of failures in dangerous places, I just put a jumper wire, from the + terminal on the battery to a fused hot terminal on the fuse panel...problem solved.
    This is as good.
    I did something as redneck wiring a GPS on my CB1100. Not having a schematic or the patience to sort through one...I just wired a power socket to the battery, and then adhesive clamps along the base of the gas tank. Run the cigarette-lighter plug-in from under the seat, along those clips, to the handlebars. NO...PROBLEM.
    With that bike's robust electrical system, I can leave it plugged in for (so far, I've tried) five hours or so, shut down, with no negative effects.
    acjlarsen likes this.
    Jun 2015
    742
    Quote Originally Posted by acjlarsen View Post
    Stator outputs AC. Rectifier converts it to DC. The rectifier also has a built-in output voltage regulator.
    I doubt that it has any noticeable current drain. The old selenium rectifiers did, but they were obsolete long before the first TW was built. All TWs use silicon rectifiers, which have negligible leakage.
    Oct 2011
    35
    Awesome. Well thanks for the advice guys! Happy riding.
  1. Battery life sucks...what battery are you using?
    By rastaman in forum Technical Help
    Last Post: 07-21-2019, 11:06 AM
  2. Replies: 3
    Last Post: 02-05-2015, 11:55 PM
  3. Luggage quick disconnect idea?
    By Bucknutz in forum Performance and Customization
    Last Post: 08-24-2013, 07:39 PM
  4. Battery Quick Disconnect
    By rhys in forum Performance and Customization
    Last Post: 11-11-2012, 11:14 PM
  5. welding.. what parts to disconnect?
    By dubstep in forum Technical Help
    Last Post: 04-17-2012, 10:44 AM
