Install bigger engine?
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Like Tree43Likes
Thread: Install bigger engine?
    Junior Member Mollybones's Avatar
    Oct 2011
    Maine
    27
    Hey Guys, Mollybones here in Maine. After well over 15,000 miles of good times and heavy luggage, my dear friend, The Ratty Pidgeon, is sucking air and it also sounds like his inner sprocket is worn out. Going to replace the engine before our next big adventure together ( The Continental Divide Trail ). Is it possible to put a 250 engine on a TW? Anyone done it before? Thanks!
    Love, Bones
    Spokane, Washington
    17,291
    Ronnydog, TW-Brian, macbig2k1 are just a few of the guys who know how to build up your TW engine. You could PM them or look for further info here on what they did.
    Mollybones and TWilight like this.
    1st John 1:9
    John 3:16
    John 3:17
    Oct 2011
    Maine
    27
    Thanks buddy. I will try to figure out how to connect on here. Bones
    littletommy likes this.
    Germany, Werdau
    1,014
    225 crank shaft (58 mm stroke) + XT250 piston (74 mm bore) + fitting bigger sleeve = 250 cc
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    8,048
    There are 2 schools on this. You can build up your existing engine to get it up to 250 CC s or you can buy a 250 from an XT and go for that. Either of these options do take a lot of intricate engine work and a good machine shop to get it done. The 250 XT engine has to have the output shaft extended and a carrier bearing added so the sprockets align. Not an easy or inexpensive task! The TW engine has to have a lot of machining of the cylinder around the base to accept the larger piston and clear the top of the case. Also a big job.
    Not saying these upgrades can't be done because we do have proof right here but there are those like me that would probably tel you to go buy an XT 250 and about all you will lose is the fat tires. You will gain power, 6 speed transmission and much improved suspension. I sure love the threads about these technical upgrades but I have to remember most of the guys who tackle such endeavors either are machinists or have one close by willing to work with them. By the time you are all done and ready for the adventures I will bet you spent more money than just buying a bigger bike would cost. Just My Opinion.
    1987 Yamaha BW350 Big Wheel
    Germany, Werdau
    1,014
    The XT250 engine doesn't fit.
    The XT/TTR 225/230 are different from the XT250.
    TWilight likes this.
    May 2014
    Yooper, MI
    1,510
    I was going to go the XT225 crank route but I decide that what I want more than just a few more horses is the six gears. I'm looking for an XT225 donor and then I think I'll upgrade to a 10.5:1 piston. There is a fellow here that does the mods to a TW tail shaft and that coupled with the TW right shaft bearing is pretty much plug and play. (Circle F Machine) This will give near 20 horses and six speeds with a lower first and a sixth that's taller than the TW's 5th to boot.
    May 2013
    Groton, NY
    2,663
    You can spend a bunch of money and time getting more ponies out of a $2000 TW and you still have a $2000 TW that is under powered and vibrates a lot.
    Dryden-Tdub likes this.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    Senior Member GHDave's Avatar
    Aug 2013
    Gold Hill, Colorado
    285
    According to Yamaha's web page, the XT250 comes with a 5-speed.
    Jun 2013
    Forestburgh, NY
    8,048
    Quote Originally Posted by GHDave View Post
    I don't know anything about the XT 250 but I do have an XT225 out in my shed and it sure does have that extra gear!
  1. Need Something Bigger and Stronger
    By Mongol Pete in forum TW200 Classifieds
    Last Post: 07-07-2014, 10:26 PM
  2. Bigger engine in the TW
    By Dako124 in forum Technical Help
    Last Post: 09-20-2013, 10:50 AM
  3. bigger pilot jet?
    By DDavis in forum Technical Help
    Last Post: 10-25-2011, 01:02 AM
  4. The Bigger engine dream
    By RisingSun in forum General Discussion
    Last Post: 07-07-2011, 03:29 PM
  5. Custom tw200 bigger engine
    By bangkokbonk in forum Performance and Customization
    Last Post: 05-16-2011, 10:41 AM
tw200 bigger engine
tw200 larger engine
