ATV Rear Tire using the TUBLISS system anyone tried it ?
Results 1 to 10 of 10
Like Tree9Likes
  • 1 Post By PlacerLode
  • 2 Post By jb882
  • 2 Post By Fred
  • 1 Post By Lyterx
  • 1 Post By TW-Brian
  • 1 Post By Fred
Thread: ATV Rear Tire using the TUBLISS system anyone tried it ?
    Apr 2012
    Out West
    3,056
    After learning about the TUBLISS system (Saw it mentioned in the classifieds section) this looks like the cats meow for our ATV tire issues in that it uses a 100 psi liner / sealer / bead lock and also allows ultra low tire pressure (w/o pinch flats) and even run flat features plus the ability to fix flats using the plug system I was wondering if anybody had tried this with a Duro or other ATV rear tire ?
    Also (I know TWilight will like this) it says it's lighter than HD tubes
    TUbliss Motorcycle Dirt Bike Durable Tires | Nuetech
    TWilight likes this.
    "It's Like Warm Apple Pie"
    Senior Member jb882's Avatar
    Aug 2013
    1,375
    Looks like they don't make it in a 14" size 18,19 and 21 which are traditional full size dirt bike sizes.
    Too bad they don't since this might be just the thing to getting it to mount and atv tire easier.
    It seems a lot like the inner liner that nascar uses at some tracks.
    TWilight and Dryden-Tdub like this.
    18,729
    Our Larry from Mississippi showed me at Moab his tube less Duro ATV tire set-up. He had sealed up his spokes on the inside with adhesive sealant more than three years ago w/o any issues since. I had read of his work years ago and was pleased it has given him long worry free service. Being able to plug a flat in the field outweighs any possible issues with potentially loose or broken spokes in my opinion.
    PlacerLode and TWilight like this.
    Senior Member Lyterx's Avatar
    Jun 2014
    Etters, Pa
    474
    Pretty sure I saw a tubeless kit for the tw on the japan webike page.
    1991 TW200
    18,729
    Have seen TUBBLISS for the front, but not for rear 14" rim.
    Trailscout indicated he had tried the 18"TUBLISS. The ~$!00 experiment dissapointed him if I recall since a front flat is so easy to fix in non-race situations. Then again last I heard he had ditched the 14" rim for a conventional 18" in the rear. Can run same trials tires front and rear. Sacrilege? Practical? Readily serviceable in Tierrra del Fuego?
    And the very last I heard he was down to riding horses....lots of them.
    Pleasanton, CA
    5,722
    Maybe we could stuff a few of these Bib Mousse things into our Duro's !
    https://www.rockymountainatvmc.com/p...usse-Foam-Tube
    https://www.google.com/url?sa=t&rct=...98476267,d.cGU
    PlacerLode likes this.
    18,729
    How many Brian? Maybe two @ $125 each?
    I'm starting to like the glue-ed up spoke idea more and more...almost as much as your 14" trailer wheel/TWhub hybrid. And how is that project coming along TWBrian?
    Apr 2012
    Out West
    3,056
    I know my Centerline racing wheels (welded seams) and Weld Racing wheels (riveted seams) seal the seam between the two rim halves with silicone but thats just in case of weld porosity. If we could seal the spoke nipples with silicone instead of epoxy then adjustments would still be possible
    Either way the tubeless approach is more and more appealing
    Pleasanton, CA
    5,722
    Fred, it is still in the works, but unfortunately not much progress lately.
    Here is what it will look like when it is done:
    (Note: This photo is of Little Big Foot's bike. I am just copying what he did)
    Fred likes this.
    18,729
    Brian's trailer rim mod looks like the way to go in order to achieve weight reduction, safety, convenience and serviceability of a no-tube ATV rear tire set up. My only question is how many miles Brian rode in order to wear down that Duro down so far....impressive
  1. FS: CO - Shinko SR244 front tire and Bridgestone TW34 rear tire
    By Nicholast in forum TW200 Classifieds
    Last Post: 12-06-2014, 10:02 PM
  2. Replies: 13
    Last Post: 09-14-2014, 10:36 AM
  3. rear tire change...surface rust...tire lube?
    By blackmouthcur in forum Technical Help
    Last Post: 04-13-2014, 09:53 AM
  4. Replies: 10
    Last Post: 12-07-2013, 05:02 PM
  5. Nuetech TUBliss tubeless tire thing
    By Skyking in forum Performance and Customization
    Last Post: 11-24-2012, 10:16 PM
