Trailer Wheel (TW) Mod for the TW200 - Page 45
Page 45 of 45 FirstFirst ... 35434445
Results 441 to 450 of 450
Like Tree1060Likes
Thread: Trailer Wheel (TW) Mod for the TW200
  1. #441
    Mar 2011
    NJ Shore / Pine Barrens
    3,880
    My XT and TTR Keep their distance when I have a wrench in hand.. lol. Actually, the ones on my xt and ttr are not nice enough to steal for the tw. Sooner or later eBay will give a nice one up
    TW-Brian likes this.
    Husqvarna TE300i Fuel Injected 2-Stroke 2019
    Yamaha XT225 - 1999 Serow
    Yamaha TW200Z - 2010
    Yamaha BW200 Electric Start! - 1986
    Yamaha TTR225R - 2003
    Husqvarna 701 Enduro - 2017
    Kawasaki Prairie 650 - 2002
  2. #442
    Junior Member OldSchoolbus's Avatar
    Sep 2017
    Bremerton Washington
    27
    So for everyone who has done the trailer wheel mod, What sprocket size are you running and are you happy with your choice? Obviously, most people who do the mod are exclusively or at least mostly running off road. I'm in the process of doing it now and am getting all the parts together and want to order a sprocket from sprockets specialties. Right now I've been running the stock rear tire with a 54 tooth on the rear. Top speed is about 50-55 but cruises real nice about 45, which is fine. I ride about 90% off road and 10% on road maybe a quick trip to the store. I realize to trailer tire mod is going to require more power to turn that heavy wheel and tire. I should also mention I weigh in about 245. I'm also considering a dual sprocket (rear) so I guess I'm asking how low is too low for gearing?
  3. #443
    Pleasanton, CA
    5,555
    I have run 55, 60 and 66 tooth rear sprockets and do not consider any of those to be "too low". For the riding that you described, I would recommend that you go with a 60 tooth sprocket (or either a 59 or 61 tooth, if you want to even out the wear).
    Here is JMPNFSH's 57/72 rear combo.
  5. #444
    Senior Member Stufidmotard's Avatar
    Jun 2017
    Greenleaf, Idaho
    121
    A 60 sprocket is a good starting point. If it turns out you want more low end then you can change out the front sprocket to a 13.
    turbodieseli4i6 likes this.
  6. #445
    Senior Member Tiny-Wheel-200's Avatar
    May 2013
    Wasilla, Alaska
    645
    Wanted to bump this up and suggest that anotger untried way to get an atv style rim on the rear is to try converting the rear hub and wheel from an older suzuki van van. I have one I might try out and see if it works. Its basically identical to the set uhh p I have on m y tw that I fabricated. This picture doesnt show the details but it is a atv style hub that bolts up to a 14? Inch rim
    TW-Brian and Ken like this.
  7. #446
    Nov 2011
    norcal nutjob
    3,276
    Quote Originally Posted by Tiny-Wheel-200 View Post
    i like the "horizontal" shock set up... is that for a different take on "bump starting?"
    curious to see what you figure out for the rim adaptation.
  8. #447
    May 2013
    Wasilla, Alaska
    645
    So after a few measurements it appears that my idea to use this wheel as a way to have a 12 inch rear atv tire on the tw w/o u of work with some modification though I'm unlikely to follow through on it. These are sweet little bikes!
  9. #448
    Member Denn's Avatar
    Dec 2018
    Arizona
    55
    Anyone update on these wheel conversions? Anyone making hub assemblies from stock rather than modifying an old hub? I can probably make my own but don't want to take my wheel apart just to get dimensions. I would nice if they were available from a CNC shop somewhere?
  10. #449
    Frosty Hollow
    12,760
    Quote Originally Posted by Denn View Post
    Forum member Studifmotard's (sic) hub is made completely from scratch and doesn't use any parts from a TW rear hub. You do not need to disassemble a TW hub/rim and can keep it intact. For Studifmotards's, you buy the hub from/through him, purchase your rim of choice, and tire of choice. While you're gathering all this you can continue to ride your TW.
    Studifmotard's made from scratch is the hub on the left in this photo
    (the brake drum not attached yet). The hub on the right was a hub made by TW-Brians acquaintance with using TW hub parts. There are a few other forum members who've made the trailer wheel conversion using different methods.
    Mel, Fred, Sthrnromr and 1 others like this.
  11. #450
    May 2013
    Wasilla, Alaska
    645
    My advice is to buy a tw hub on eBay and go from there. You'll still have your old wheel intact but if your experience is like mine you'll never use it again!
    Fred likes this.
  1. 2 Wheel Tank Trailer
    By ronnydog in forum Performance and Customization
    Last Post: 04-26-2017, 11:55 PM
  2. Trailer Wheel Bearings
    By elime in forum General Discussion
    Last Post: 09-22-2014, 06:15 PM
  3. Custom Built Trailer Hitch Carrier for a TW200
    By Fursniper in forum General Discussion
    Last Post: 09-17-2014, 10:39 PM
  4. Oh my, a 3 wheel TW200
    By unclejemima in forum General Discussion
    Last Post: 07-21-2012, 02:18 PM
  5. trailer pulled by a TW200
    By RingSteel in forum General Discussion
    Last Post: 07-07-2012, 08:52 PM
bob trailer for tw200
news
rear hub
trailer for tw 200
trailer for tw200
trailer to pull with a yamaha tw200
tw 200 on sedona trails
tw200 mods
tw200 sedona ripsaw
tw200 trailer
tw200 trailer rear wheel
tw200 trailer wheel mod
