ttr225 piston in a tw200 cylinder
Results 1 to 4 of 4
    Junior Member racerx's Avatar
    Aug 2010
    16
    Does anyone know if I can bore the stock tw200 cylinder to the stock or oversize ttr225 piston? Thanks any help would be appreciated.
    Member dawgs's Avatar
    Aug 2010
    64
    Don't think so!
    The biggest oversize available is 1.0mm That adds about 6cc.
    Poway CA.
    2,102
    Quote Originally Posted by tommy81 View Post
    No.
    Ronnydog
    Germany, Werdau
    1,014
    It's better to order a new sleeve (from LA Sleeve) for the 225 pistion.
  1. Just bought my 2nd TW200 and the piston is damaged
    By ishootstuff in forum Technical Help
    Last Post: 01-07-2013, 10:16 AM
  2. ttr225 header
    By kripton in forum Technical Help
    Last Post: 06-04-2011, 05:43 PM
  3. TTR225 engine in a TW200, extended front sprocket shaft?
    By Skullhag in forum Performance and Customization
    Last Post: 05-01-2011, 07:27 PM
  4. Cylinder and Piston
    By Desertwndrr in forum Performance and Customization
    Last Post: 01-06-2011, 03:46 PM
  5. Posh Faith TW200 piston
    By Mame Shiba in forum Performance and Customization
    Last Post: 12-29-2010, 07:58 PM
