47 Tooth Sprocket
Results 1 to 10 of 17
    Senior Member FnMag's Avatar
    493
    Well I finally got my chain and this morning I took the rear wheel off, replaced the stock sprocket with a 47 tooth and replaced the chain.
    When I was all done, I took it out for a spin around the neighborhood. In the back of our subdivision, they have paved a new road but have not begun work on any houses yet. I wrung her out with some acceleration runs and I must say I am more than impressed with what a difference the 47 tooth made.
    There is a sink hole/severe weather pond type thing where some of the other neighbors have made trails to and 1st still has plenty of low end to get through the muck.
    I'm a camper !!!
    So a big thanks to all those that have helped me with my numerous questions.
    Member poweber's Avatar
    Aug 2010
    Hellertown, PA USA
    86
    I'd sure be interested in another follow up to see how you like the 47T sprocket and how it performs, especially if you have some hills on the roadways. I have some moderate hills here in East-Central PA and it kinda' lugs a little with my fat-a** (205 lbs) on the seat anyway. I've been contemplating that mod for some time now.
    Happy Trails,
    capt pow!
    2010 TW200, factory rear rack, Chinese jumbo footpegs, Jimbo windshield, ScalaRider G4, Clarke 2.7 Gallon tank, Koso tachometer, Stearns seat cover, gel grips, Dirtly 1" handlebar risers, Osram Rallye H4 bulb, Cortec Deluxe rear bag .
    1993 TW200 in Meridian, Idaho
    1,533
    I recently changed my sprockets and chain and put a stock 14 tooth front and 47-tooth rear. It's pretty subtle, but I think I probably am getting about 5 mph more at the top end. 1st and second gear still have plenty of low end torque. Out on most streets around town I'm still in third or even fourth gear by the time I'm across an intersection as I pull away at a stoplight. You'd have to really get pretty radical with your sprockets before you'd kill the trail-bike characteristics of a TW and you're never gonna make it a real "street bike" (nor would I think you'd want to).
    918
    I really like my 47t. It feels like the stock 50t without as much buzz.
    Sold bike.
    1,533
    Quote Originally Posted by pgilles View Post
    I'd agree with that. It's subtle, but noticeable. I'm glad I switched.
    Senior Member srs713's Avatar
    Smyrna, GA, USA
    1,417
    I changed to 15/47 shortly after buying my bike. I liked having more time in 1st gear rolling away from stop lights. But I felt I'd lost just a bit too much torque. Head winds were kicking my butt.
    So when the stock chain wore out & I got my O-ring replacement, I switched to 15/50.
    I've only ridden a dozen miles or so with these sprockets, so I don't have a good feel for them yet. But reving out in first still lets me get moving before needing to shift. So I think I'll like it.
    My 15/50 is VERY close to 14/47 so should be about the same performance.
    Stephen S.
    '07 TW200:
    Quote Originally Posted by srs713 View Post
    I was also not real happy with 15/47 sprockets I put on when facing a long stint of highway only use. I went to 15/54 on the next set since I was going to be doing a lot of dualsporting. Now I alternate between the 54 tooth for dualsport use and a 50 tooth for the street. For me 15/50 is a lot better on the road than 15/47.
    918
    Agreed on both. I had tried the 14/44 (3.14 vs. 3.13 for 15/47) and did not like it and I run the streets. Lost too much torque, 5th gear wasn't useable for any extended amount of time.
    Sold bike.
    493
    Well, after my ride the other day, I have to say that I am happy with my decision to go to the 47 tooth rear sprocket. I don't have many hills down here in SE Alabama, but the ones that we do are usually pretty long ones and the TDub did just fine with my fat ass on it !
    Senior Member wrench-puller's Avatar
    Ladysmith, B.C.
    548
    Hey Mike, glad you like the set up. I am very pleased with my 47T and I do lots of both on and off road with both steep trails and highway slopes. How did you make out with the chain, that 120 fit OK? Don't forget the master link has to go on in one direction only as per the instructions.... yeah it did come with those. The closed end of the link lock should be to the rear on the lower side of the chain so if you get stuck in the gravel or mud you dont push it off. Anyhow, just wanted to say hi and glad you liking the gear choice.
    2009 TW200, Jimbo shield, 47&55T rear with DID chain, Maxxis Ceros Rear, Kendra 270 front, extended swing arm, 1"Risers, Rear rack, Raised front fender, XOG GPS.
  1. Replies: 0
    Last Post: 06-14-2012, 04:13 PM
  2. 13 tooth sprocket
    By PalmStateCrawler in forum Technical Help
    Last Post: 12-12-2011, 11:28 PM
  3. 60 tooth sprocket HELP
    By cthunter in forum Technical Help
    Last Post: 06-27-2011, 04:44 AM
  4. 47 tooth sprocket
    By mga60tw in forum General Discussion
    Last Post: 10-08-2010, 12:31 AM
  5. 13 tooth sprocket
    By Honda710 in forum General Discussion
    Last Post: 08-19-2010, 09:17 AM
47 tooth rear sprocket fot tw 200
47 tooth rear sprocket on tw200
48 rear sprokets for yamaha tw 200
spracket with 47 teeth
the best 47 tooth rear sprocket tw200
tw 200 high octane
tw200 15 tooth front sprocket
tw200 47 sprocket
tw200 47 tooth rear sprocket
tw200 47 tooth sprocket
yamaha tw200 47 tooth rear sprocket
yamaha tw200 with a 15 front sprocket and a 48 rear sprocket
