How do I change the front sprocket?
Results 1 to 7 of 7
    Member wvhunter's Avatar
    Apr 2011
    34
    I just got my JT new front sprocket, but how do I put it on? I havn't even looked at it yet, I'm just trying to get some ideas on how to do it more easily. Also, what type of oil do you guys use? The guy at the local Yamaha dealership said that you didn't have to use the more expensive Yamalube. Is this fine for them?
    Ephrata, WA
    1,125
    You need to take off the left side engine cover. Some drain the oil while others have laid their bike over so they don't have to do an oil change. Be very careful when taking off the cover so you don't rip the gasket. I buy a new gasket when I change my front sprocket. The cover should come right off, but remember, the stator is in there which is magnetized and it may take a gentle tug to get the cover off.
    When the cover comes off, there will be some wires coming out of it. I zip tie the engine cover to the frame near the passenger peg.
    There should be two small bolts holder on a keeper, which holds on the sprocket. Take off the two bolts, turn the holder and take it off and the sprocket will slide right out.
    When putting the cover back on, MAKE SURE YOU DO NOT PINCH THE WIRES!
    1990 TW200
    Apr 2011
    34
    Thanks Rainman. I'll drain the oil, since I need to change it and the oil filter anyway.
    Senior Member phazer's Avatar
    Jul 2011
    putnam,ct
    428
    i use torco motor oil, the clutch loves it!!!!!!!!
    Jul 2011
    putnam,ct
    428
    866
    Quote Originally Posted by mr zannini View Post
    Dumonde Tech YAP400 is the way to go.
    Any oil that is slippery enough to lube the piston, not so slippery as to affect the clutch, and tough enough to withstand the extreme pressures of the valve train of a 10,000rpm engine will do.
  1. Change sprocket with chain at 1,000 miles?
    By steve_tb in forum Technical Help
    Last Post: 04-25-2014, 09:42 AM
  2. Sprocket(s) Change!
    By Swamp in forum Technical Help
    Last Post: 04-27-2013, 08:40 AM
  3. Do I need to drain the oil to change front sprocket?
    Last Post: 01-12-2013, 11:37 AM
  4. Does minor sprocket change affect top speed?
    By RingSteel in forum Performance and Customization
    Last Post: 03-13-2012, 07:59 AM
  5. Rear sprocket change out
    By k9scooter in forum Technical Help
    Last Post: 10-06-2011, 06:05 PM
changing 2013 tw200 front sprocket
changing front sproket on a tw200
changing tw200 front sprocket
google how to change out front sprocket on yamaha tw
how to change front sprocket on a tw200
how to change front sprocket tw200
how to change front sprocket yamaha tw200
sprocket changing on yamaha tw200
tw200 change sprockets
tw200 sprocket change
what kind of oil should i put in my yamaha tw200 left cover
yamaha tw200 sprocket change
