Footpeg Vibrations
Results 1 to 10 of 18
    Aug 2011
    Cayce, SC
    3,109
    When I get up to high rpm(50+mph) my footpegs are vibrating a lot. I wonder if there is a liquid rubber dip that i could coat them in or some other cheap way to fix this. Any help/ideas would be greatly appreciated!
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    Desert, SoCal
    7,369
    Check and torque your motor mounts and swingarm bolt first. It'll probably go away.
    Aug 2011
    Cayce, SC
    3,109
    It's a 2010 with just 22xx miles. I had it serviced at 500 miles but I never got it higher than 50mph until it broke 1000 miles. I will look into the motor mounts and try to find the swingarm bolt, whatever that is... i'll check those out tomorrow. thanks lizard
    Senior Member wrench-puller's Avatar
    Ladysmith, B.C.
    549
    Are you still running a stock chain? I switched to a DID oring chain when I did the rear sprocket swap at 450 Km on my '09. Not only did I get the lower RPM on the highway I wanted, but almost all of the vibration was gone. Now I can cruise at 90 to 100 Km/hr and all is smooth, just that good old butt ache after an hour or so. ( Also havent had to adjust my chain all summer!)
    2009 TW200, Jimbo shield, 47&55T rear with DID chain, Maxxis Ceros Rear, Kendra 270 front, extended swing arm, 1"Risers, Rear rack, Raised front fender, XOG GPS.
    Aug 2011
    Cayce, SC
    3,109
    Still stock chain and sprockets. I'm going to wait till they really need to be changed. Good to know though. Money's kinda tight right now and i still need a good wintertime windshield..I'll see if the motormounts and swingarm tightening helps
    Desert, SoCal
    7,369
    Don't forget to pull the tank and torque the top mount bolts, which are often loose.
    Hope it solves or diminishes your problem, but it's the first thing I'd check, and it's free.
    Aug 2011
    Cayce, SC
    3,109
    All bolts were tight except for one nut. It is the one benind the clutch side footpeg. It also is the only one with a bracket on it, im guessing to keep the wires tucked in... I rotated it several turns but it is not moving down the threads. What am i doin wrong??? This is a pic of the nut im talking about
    Desert, SoCal
    7,369
    The bolt is turning. Go to the other side of the bike and find the other end.
    That's your main motor mount, and probably the source of the vibes.
    Senior Member Xracer's Avatar
    Lake Placid,Florida
    3,750
    Now is a good time to buy a tube of blue Loctite. Also for the furture a set of I.M.S. pegs reduced the vibes for me.
    Aug 2011
    Cayce, SC
    3,109
    It appears that there are two nuts on there, one against the frame and then the small bracket with another not holding the bracket between the two(see pic). I have tightened the motor mount to where it doesnt move but the outside nut just spins around and around either way, I cant even take it off?! The tightening definitely helped with the vibrations but now the little bracket just dangles freely... i cant figure it out for some reason
  1. footpeg offset
    By joeband in forum Technical Help
    Last Post: 09-22-2012, 08:30 AM
  2. Chronic effects from handlebar vibrations?
    By Mark In WA in forum General Discussion
    Last Post: 12-30-2011, 06:29 PM
  3. GPS survive vibrations
    By ezman671 in forum General Discussion
    Last Post: 11-17-2011, 08:15 PM
  4. Footpeg options!
    By yamamont in forum Performance and Customization
    Last Post: 11-11-2011, 11:59 PM
  5. Handlebar Vibrations
    By PalmStateCrawler in forum General Discussion
    Last Post: 09-30-2011, 04:43 PM
