Mikuni 30 MM ebay carb
Results 1 to 10 of 17
    Senior Member Stromper's Avatar
    Oct 2011
    Eastern Connecticut
    443
    My stock Cali tw carb is ridiculous
    At 45 degrees it was still on the enricher after 10 minutes
    So looking around there was a few listings for very old conventional mikuni 30mm carbs
    and they were cheap like 28 to 40 dollars.
    I am trying to rejet the teikei as per the forum
    130 main 34 pilot Note over yesterday stadium web would not work
    so emailed them and will see when they are up.
    Thanks qwerty
    But a whole new slightly bigger carb not jetted for the EPA
    sounded pretty tempting and you can buy any internal part
    jets jet setter etc.
    Devon, England.
    614
    A 30mm Mikuni is too big for a standard TW.
    You must have a problem with your standard carb beyond the normal slightly lean factory setting.
    Go through the carb cleaning and setting posted on the forum thoroughly and you will see a great improvement without any big expense or head scratching finding base settings and final tuning of a different carb, not to mention fitting it up properly.
    Tdub will cold start with no enrichment at 45*F, but will need some finesse with the throttle to bring her to a fast idle. She will ride off with near-normal throttle response after a long enough warm-up to don helmet and gloves. Something is wrong with your carb. I would expect a fuel circuit obstruction, probably pilot circuit.
    There is a lot more wrong with the thinking of amatuer mechanics than there is with any carb Yamaha ever bolted on a TW.
    Oct 2011
    Eastern Connecticut
    443
    Well
    When ever I think of C.A.R.B. in California
    I have no confidence in what jets etc. would be in anything
    The parts diagram shows little difference
    Yes when I get the jets to put in she will get
    a thorough going over and yes I suspect that the tiny passages have some kind
    of mung in it. Especially since she was sitting for a while
    Senior Member rm_hm's Avatar
    1,619
    A primer on carbs
    http://www.dansmc.com/carbs.htm
    How to clean a Tw teikei carb
    http://tw200forum.co...-carb-cleaning/
    Others with lean running tw's
    http://www.google.co...iw=1011&bih=566
    If you insist on finding an aftermarket carb here are some more links
    Now back to my rainy day of reading forums and cleaning house
    Senior Member evan's Avatar
    Aug 2011
    Woodland, California
    2,126
    I agree its your carb that needs cleaning. Mine didn't want to start easily every time while riding Forresthill OHV (4,000 feet?) with friends sunday. I know the bike has been sitting for long periods of time before I bought it so gonna give it a carb clean out since won't be riding it for a few weekends. I am going to change main jet to one size bigger cuz I've heard/read they run them just a tad lean. Other then the hard starting issue bike climbed hills fine and I loved the 75 degree sunny day!
    Oct 2011
    Eastern Connecticut
    443
    I am going to get the jets
    I guess that the airscrew adjustment will have the best change
    I will do the pilot air jet and add a hardware store fuel filter
    My DRZ400S was misserable until I went 1 size bigger
    Tomorrow I will chase after some Yamaha place for the jets
    If yours is a toy not a commuter I wouls recommend
    Always leave her filled
    Add Stabil
    Add Seafoam
    If anticipating 1 month sleep+
    Drain or run her out of gas in the carb
    i have no problem with fuel preservatives in gasoline--treated gasoline will keep for years. Gasohol will not, no matter what treatment is used. I'd drain the tank and spray it with fogging oil, which keeps the tank from rusting. Then run the carb and fuel lines dry.
    Desert, SoCal
    7,369
    My standard rant:
    There is NO (none, zip, nada, zero, zilch) difference between a Cali carb and a 49-state carb other than RICHER jetting and the fitting for the canister.
    While we're at it, the canister has NO (none, zip, nada, zero, zilch) effect on performance and causes NO (zero, zip, nada, zilch) service problems. It also has NOTHING (zero, zip, nada, zilch) to do with carb function. It's a tank vent.
    Non-issues, unless you've spent way too much time on ADVrider.
    Rant over til next time someone blames their Cali carb for the Lincoln assassination....
    Oct 2011
    Eastern Connecticut
    443
    I have ordered the jets from Bikebandit.com over the phone
    Could NOT get anywhere on Stadium Yamaha, site crashed, did not answer etc.
    Thanks for the part numbers they went right through
    Yes, I have fear of anything ECO related, I was shoveling this last Saturday
  1. 1991 carb help
    By Snake2715 in forum Technical Help
    Last Post: 03-01-2014, 08:07 AM
  2. Searching for a Mikuni TM28-1 pumper carb overseas
    By PalmStateCrawler in forum Performance and Customization
    Last Post: 06-24-2013, 03:19 PM
  3. Mikuni TM28 Carb kit & Oem tk *SOLD*
    By PalmStateCrawler in forum TW200 Classifieds
    Last Post: 04-25-2013, 09:49 PM
  4. Is the OEM carb a Mikuni carb?
    By macbig2k1 in forum Technical Help
    Last Post: 01-29-2013, 05:50 PM
  5. 30 mm ebay carb
    By Stromper in forum Performance and Customization
    Last Post: 12-21-2012, 10:43 AM
ebay tw200 carburetor
putting a mikuni carb on a tw200 forum
what is cab adjustment for 30 mm carb
