XT350 Tank Installed
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By elime
Thread: XT350 Tank Installed
    Senior Member ezman671's Avatar
    Jul 2011
    Spacecoast, FL
    178
    With the help and guidance of prior posts ( Thanks Peruano, MrGizmo and more ) about using a XT350 tank I successfully installed a new used XT350 tank on my 1996 TW200.
    Got a piece of 1x1x0.125 aluminum to make the bracket from Aircraft Spruce and Specialty. I have bought various material many times from them in the past for an aircraft project.
    Price was fine $3 something a foot but shipping hurt the deal. I will be posting in the classifieds but I have enough left over for 2 or 3 brackets if anyone is interested in this material. Aluminum "U" Channel --- SOLD OUT ---
    Hacked away at the plastic ribs of the seat pan and as you can see it has a good bend in it. Still will not bend enough for the seat to slip into the notch but I plan to ride it as is for awhile and maybe with weight on it the bend will increase to where it will fit better.
    Nov 2011
    norcal nutjob
    3,301
    Quote Originally Posted by ezman671 View Post
    looks good! did you cut off the original mounting "post" or just slip the new bracket over it, where that front hole is? i'd like a cut of your left over stock. can you cut it for a price?
    thanks,
    joe
    Jul 2011
    Spacecoast, FL
    178
    Quote Originally Posted by joe band View Post
    thanks,
    joe
    I did cut the mounting post off flush with the new bracket. I'll send you a piece of the "U" channel but I would rather let you cut it to fit. It cuts easy. Just hacksaw the front part and drill 2 holes. Let me know via PM if you want a piece of the channel.
    Senior Member r80rt's Avatar
    Sep 2011
    2,431
    I'll be going to a motorcycle salvage yard Tuesday looking for a XT350 tank, that looks great.
    6,954
    On the adapter piece you cut out, is the height on the back part 1" tall? Does it lean forward?
    Did you place the tank full forward on the front rubber mounts or did you pull it back a little bit?
    How much clearance is there between the petcock and the head on the other side?
    Desert, SoCal
    7,369
    Quote Originally Posted by Tony View Post
    Due to minor bike-to-bike and tank-to-tank differences these installations have all been slightly different.
    Almost all TW's steer further in one direction than the other (usually to the left), so keep that in mind when working out any setback or it can ding your tank and make using the steering lock a hassle. Keeping the rear of the tank as low as possible gives you more fuel and makes the "bendy-seat" thing easier to deal with in terms of removing/installing the seat and it increases tank-to-fork clearance. You'll need all you can get if you want to keep it fully forward.
    Mine is fully forward on the donuts, but it lightly kisses the tank when turned left with the steering locked. No clearance issues with the Yamaha petcock.
    Lower Rio Grande, New Mexico
    1,702
    I pushed my first xt350 tank back a bit, but eventually decided it was not necessary. The second install (recent one) I did not (was able to use same bracket) and I may just have a contact on one side when bars turned full circle, but it has not scarred, marred, or bothered tank. Tom
    Central New Mexico
    6,954
    I made a mount for the back of the XT tank -- the original TW mount had been cut off -- I welded the mount to the frame and the rear of the XT tank is 1" above the frame.
    With the tank all the way forward the handle bars hit the tank and it has not hit the stops on the lower triple tree thing. I think if I raise the handle bars there will be enough clearance but then the upper triple tree might be a problem. If the triple tree does hit then maybe a light tap with a ball peen hammer is in order, providing the fork wont hit.
    If the fork looks like they will hit I will try sliding the tank back slightly.
    The petcock is about 1/4" from the head. Maybe Yamaha makes a different petcock that will solve that problem and I can lower the back of the tank some more.
    The tank swap isn't a bolt on and compromises have to be made. However I would still consider it easy.
    JerseyJeeper likes this.
  1. Yellow Tank Installed
    Last Post: 06-22-2013, 11:18 AM
  2. XT350 tank for only $100
    By old white truck in forum TW200 Classifieds
    Last Post: 02-10-2013, 09:19 AM
  3. XT350 tank and Banshee shock (tank sold)
    By Beewerks in forum TW200 Classifieds
    Last Post: 08-30-2012, 08:01 AM
  4. WTB xt350 tank
    By joeband in forum TW200 Classifieds
    Last Post: 11-30-2011, 11:18 AM
  5. XT350 gas tank...does it fit?
    By glas482 in forum Technical Help
    Last Post: 02-03-2011, 03:03 PM
image yamaha 200 tw without plastic removes
swap fuel tank on tw200
yamaha xt 350 steering lock not working
yamaha xt 350 tank
