Summary of Modifications: Carburetor and Drive Train
Results 1 to 6 of 6
    Junior Member peraevum's Avatar
    Jan 2012
    Chicago, IL
    14
    I just bought a 2011 TW200 for my very first beginner motorcycle and am loving its forgiving nature. After reading about everyone's modifications, I'm going to get some done on my bike too, but since I'm a noob and have no idea how to purchase and install some of these parts, I'll have the dealer do it (this time). Can you guys confirm whether my list is right?
    1. Change out 14 tooth front sprocket to 15 tooth sprocket.
    If I do this, it sounds like what is currently second gear will become my first gear. It is a little bit difficult for me to start the bike in second gear though, and I was wondering if changing out the sprocket will make starting out in first gear just as difficult. It would be great to change it out though, because first gear is frustratingly short to me. Also, does sprocket brand matter or are they all pretty homogenous?
    2. Change out 50 tooth rear sprocket to 47 (or 45) tooth sprocket. Is this in addition to the front sprocket change or do I pick one or the other?
    3. Change out stock chains to DID 428 O-Ring Chain and get the 130 link package.
    4. Re-jet the carburetor from default 128 to 130 (or 132.5)
    5. Shim the needle .03 inches (what does this do hypothetically?)
    6. Turn the air screw 2.5 turns (what does this do hypothetically?)
    7. Do something to adjust pilot mixture screw?
    Karen
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,405
    Quote Originally Posted by peraevum View Post
    Changing the rear sprocket is easier, and cheaper, if you are paying for labor.
    Personally, I would get a few thousand miles use out of the stock chain before I switched. You will get differing opinions on this.
    ...5. Shim the needle .03 inches (what does this do hypothetically?)
    Karen
    It slightly raises the main fuel needle to allow more fuel through the main jet. It gives a richer fuel mixture at throttle openings above idle speed.
    Karen
    The air screw and the pilot mixture screw are the same thing.
    Opening it to 2.5 turns gives a richer air/fuel mixture at idle speed, making it easier to start the engine. The 2.5 turns may need to be fine tuned. It may vary because of air tempurature, humidity, altitude, etc. Mine is set at 2.25 turns.
    IMO, other than opening the pilot screw 2.5 turns, I would wait on any mods until after engine break in, 600-1000 miles.
    Good idea to change the engine oil between 100-200 miles on a new engine.
    jb
    Jan 2012
    Chicago, IL
    14
    Thanks jb, that's helpful. So it sounds like I should not change out both sprockets, right? If I get 15 on the front, do not get 47 in the back? And it will be slightly more difficult to get going on the bike in first gear after that, similar to how starting off on second gear is now?
    FL. GA, NC
    2,405
    Yes, I would wait until the 14 tooth front sprocket is worn out before I would consider changing it. You can make any necessary gear ratio changes by changing the rear sprocket.
    The only advantage of the 15 tooth front sprocket is marginally less chain wear because of the larger diameter of the 15 tooth sprocket.
    ... If I get 15 on the front, do not get 47 in the back? And it will be slightly more difficult to get going on the bike in first gear after that, similar to how starting off on second gear is now?
    Changing the front sprocket involves draining the engine oil (unless you lay the bike on its side) and removing the engine cover, and perhaps getting new sprocket bolts.
    Putting on a 15 tooth front sprocket alone will give you about the same sprocket ratio (15/50) as putting on as a rear 47 tooth rear sprocket (14/47).
    Start in first gear in either case.
    jb
    Desert, SoCal
    7,369
    47/14= 3.357:1
    50/15= 3.333:1
    Effectively the same. Gearing changes are always` easier on a TW via the rear sprocket.
    Senior Member bcscammell's Avatar
    Oct 2011
    264
    That's some good advice jbfla. It's always better to live with the bike for awhile, as is, and then see what mods you really want and need, with the possible exception of the carb adjustments.
  1. Who Said You Need 4 Wheel Drive
    By ronnydog in forum General Discussion
    Last Post: 11-09-2012, 08:55 PM
  2. TRAIN Grafitti
    By Batman1USA in forum Trails, Off-road, and Adventure Riding
    Last Post: 05-04-2012, 09:19 AM
  3. Accessories and modifications for TW-200 2012
    By JoseARuiz in forum General Discussion
    Last Post: 03-29-2012, 09:18 PM
  4. Carburetor help or different carburetor options
    By dz1 in forum Technical Help
    Last Post: 05-21-2011, 09:24 PM
  5. Wagon Train Ride
    By admiral in forum Off-Topic
    Last Post: 10-29-2010, 06:18 PM
