Counter-shaft Sprocket Coverectomy
Results 1 to 9 of 9
    Senior Member Mad Mac's Avatar
    Texas
    200
    My new old 2001 has a mangled counter-shaft sprocket cover.
    I want to change the 14 tooth sprocket to a 15. I'm thinking about taking my angle grinder with a cut off wheel to the cover. That would remove the offending bit and allow access in the future for easier sprocket swapping, killing two birds with one grinder you might say.
    Where is my thinking flawed? Will the sprocket eat my jeans? I noticed even the hollow mod TWs with no chain guards do not expose the counter-shaft sprocket. Thought I should run it by the cognoscenti before I do harm.
    2001 TW200 adopted January 2012. 2001 Moto Guzzi California EV acquired June 2012. Ex-rides: Hidden Content , Hidden Content that I rode 67,000 miles in six years and had many Hidden Content , 1979 Yamaha RD400F Daytona Special, Yamaha XT 500, 1969 Yamaha DT 175 Enduro purchased new that started it all and a Honda 90 and 110 ATV, an Indian Mini Buffalo (a 50cc Italjet) and a couple of other dirt bikes.
    Ephrata, WA
    1,125
    I think Mr. Gizmow did that.
    1990 TW200
    Desert, SoCal
    7,369
    Keep it minimal. There's an oil passage and a bearing in the cover.
    You wanted someone to stop you, no?
    The countershaft sprocket cover cannot be removed because it houses a bearing that supports the outboard end of the countershaft. Any mod that will allow removing the sprocket without removing the cover will remove the bearing, causing bad things to happen to the countershaft, trans, and engine cases.
    Grind it smooth inside and out and call it good.
    Texas
    200
    In the immortal words of Gilda Radner's character
    on Saturday Night Live, Emily Litella,
    "Oh. That's very different. Never Mind"
    Thanks, you guys.
    Senior Member Omega Man's Avatar
    Jan 2012
    Taxachusetts
    173
    While the subject is up....I just ordered the side case gasket so I can change the sprocket. Is there something that I missed and should have ordered? TIA Gary
    "It's more fun going fast on a slow bike than going slow on a fast bike" UK
    1994 TW200, 2009 F800GS loaded,
    Senior Member Gerry's Avatar
    Paradise, Calif.
    3,513
    Given my experience, I am inclined to say you can trim away what is damaged, just don't roll over the edge and begin cutting the face of the case. What I think is a better idea would be to carefully tap the 'flaps' downward to present you with a depression. Clean the case area top and the underside facing the chain so that it's free of oil and dirt. Rough up the area with a bit of sandpaper, don't scratch up the area much beyond what is damaged. Use some JB weld putty to fill in and sand to restore original contour. Carefully spray that section of the case with some paint and you will be back to looking good. As was mentioned, that case section can not be trimmed to make sprocket removal any easier. I trimmed my case so I can watch the chain move from one primary sprocket to the other when I switch ratios. Gerry
    Take care my Friend.........
    Senior Member xdac's Avatar
    Mar 2011
    Gilbert AZ
    1,076
    Hey look we're twins
    I run o-ring chains so replace the countershaft seals each countershaft sprocket change. Seems that the seals wear out almost as fast than an o-ring chain, and if I don't change them, I'll be pulling the cover again shortly after installing the countershaft. Both seals together cost about $9, so the added expense is worth the reduced maintenance down the road.
  1. adding a Rev counter and better Lights
    By dubstep in forum General Discussion
    Last Post: 02-07-2015, 01:53 PM
  2. Changed the counter sprocket and now the bike won't start
    By rurlndum in forum Technical Help
    Last Post: 06-22-2013, 07:05 PM
  3. Crankshaft doesnt turn counter clockwise
    By fredzaha in forum Technical Help
    Last Post: 06-17-2013, 08:17 AM
  4. TTR225 engine in a TW200, extended front sprocket shaft?
    By Skullhag in forum Performance and Customization
    Last Post: 05-01-2011, 06:27 PM
  5. cam chain sprocket on the crank shaft
    By christddel in forum Performance and Customization
    Last Post: 02-02-2011, 12:05 PM
easier access to counter sprocket tw200
sprocket front access
