Installing AfterBurners
Results 1 to 10 of 11
    1993 TW200 in Meridian, Idaho
    1,533
    My step-son just bought himself a Suzuki 650 "crotch-rocket." (Can't recall right off-hand the model, but it's scary-fast). I knew if I was to have any hope of keeping up with him on even a casual ride there was only one answer - Afterburners!
    So... a couple of hours at the workbench and I had 'em ready! Just stand clear when I fire'em up!
    OK, maybe not. What these really are are my newly installed Agri-Supply storage tubes which I learned of in another thread here. I simply mounted them to my rack with zip-ties and, having found some reflectors the same diameter as the end cap at Harbor Freight, stuck those on. The tubes will hold bottles of water, cans of your favorite beverage, tools, a first aid kit, or whatever else you dream up. They are 12" long and 3 1/4" in diameter. I like 'em!
    Get 'em here -- AgriSupply
    Senior Member ATXthumper's Avatar
    Aug 2010
    Austin, TX
    231
    lookin good! the reflectors are a perfect fit!
    '01 TW200: Tusk D-Flex Handguards w/ Spoilers, Pro Taper Grips, LEDs in Idiot Lights, Headlight Rockguard, Stearns Seat Pad, Oversized Footpegs and a Loud Ass Horn -SOLD
    '91 TW200: Bone Stock
    Lower Rio Grande, New Mexico
    1,702
    You will want to keep an eye on those wire ties. I've found that even the black (uv resistant), but especially the white ones get brittle with age and or wear with vibration. I can think of innumerable ones that I have found either broken or missing where I tied something onto the TW. I'd bolster with real metal bands or the strongest wire ties I could get unless its something you remove frequently enough to keep the ties fresh. Tom
    Central New Mexico
    Senior Member Boret's Avatar
    Aug 2010
    Northern VA
    404
    You can actually fit a 33oz bottle of fuel in those agrisupply containers.
    These images come from this Advrider thread (the credit goes to murgatroid42)
    I have 2 on my Vstrom and will put two in the Tdub. The will give me 1/2 a gallon extra of gas, about 30-40 miles of extra range.
    Aug 2010
    Northern VA
    404
    Another piece of info, you can use break/carb cleaner to remove the yellow graphics, in a matter of seconds.
    1,533
    Quote Originally Posted by Boret View Post
    I used Goof Off, per someone elses recommendation and the yellow paint came off very easily.
    Senior Member darnold87's Avatar
    Salem, OR
    908
    Nice photochop of the afterburner flames
    Yeah, these tubes are great... endless uses for them.
    ~Davey
    '89 TW200
    '94 Suzuki Sidekick
    Senior Member HenryJ's Avatar
    Oregon, USA
    184
    Great tubes on fire!
    I like them too:
    I mounted mine under the rack so I had room for the action packer on top.
    You can fit a medium size trunk with the tubes on top of the rack too.
    That is what I did on my KLR.
    "Speed doesn't kill, suddenly becoming stationary does." - Richard Hammond
    "Speed is just a matter of Money - How fast do YOU want to go?"-Mechanic from Mad Max-
    If at first you don't succeed - Don't take up Skydiving!
    - Hidden Content
    Member drob's Avatar
    Aug 2010
    North Idaho
    78
    Thanks for the heads up and link to Agrisupply.
    A few people on fleaBay are selling the same things for $12-38...
    I much prefer $5 each!
    - 2004 TW200 - Jimbo's Shield - Ricochet plate - Cyclerack - SoftBottom pad - wide pegs - siderack for saddlebags - RotoPax - Maxxis 6006 tire
    Member Gunner's Avatar
    62
    For mounting tubes, if you have a friend who's a cop get flex cuffs. Or go to Galls.com and order your own.
  1. installing Bridgestone TW203/204's difficult?
    By GlassAnkles in forum Technical Help
    Last Post: 08-28-2013, 08:40 AM
  2. Installing TTR225 clutch
    By yz250f4ever in forum Technical Help
    Last Post: 01-24-2013, 10:10 AM
  3. Installing O-Ring Chain
    By Justin5117 in forum Technical Help
    Last Post: 05-26-2011, 02:14 PM
  4. Installing a 320mm brake disc
    By sinophilia in forum Performance and Customization
    Last Post: 01-25-2011, 05:45 PM
  5. Installing 12 Volt Relays
    By Petrus in forum Technical Help
    Last Post: 10-07-2010, 11:09 AM
