"my" jetting with DG pipe and stock airbox
Results 1 to 3 of 3
    Member Kirk Ross's Avatar
    Feb 2012
    Owasso Oklahoma
    38
    Howdy folks, I just thought I would share my jetting since I have added the DG "O" series pipe, (ran good with stock jets, but has always been cold natured anyway and I wanted to richen it up a lil... I drilled out the fuel screw cap, and backed out the screw 2 1/2 turns, stock main jet on my 07 is 128 hex head, and I shimmed the needle up with two small lock washers I hammered flat (from home depot)
    originally I tried a "TK 130" main jet I ordered online and it worked OK but, it was a slotted head, not hex the bike seemed to bog ever so slightly when you gassed it in first gear (when I pop the front wheel up it would kinda fall instead of pulling on up...so I put the "stock" main jet back and problem solved, no bogging or cutting out and good smooth power through all gears, I havent had it WO in fifth gear yet but will try to report if theres any issue later (like if I need to remove a shim or something)...right now I can start the bike with a cold engine (it was 80 degress today, so not really cold) with no "choke" hit the button and she is ready to ride...
    Oh, and I also replaced the stock carb bowl screws with some allen screws (so in the future I wont round out the super cheesey stock screws
    ALSO, I never took the carb off the bike, by simply removing the throttle cables (just loosen the cable nuts, not the bracket they mount to, no need to, undo anything further) I could turn the carb in the boots to get to the bowl, as well as the needle from the right side of the bike, "IMO probly the best method" as I havent tried it any other way but after doing the main jet twice in hardly any time Im not sure how you could do it any easier
    Im no expert but If this is interesting or helps even one person then to me it was worth putting on here
    Kirk Ross
    1973 Honda CL100 Scrambler
    1983 Yamaha XS650 Heritage Special
    1996 Yamaha YZ250
    1997 Kawasaki KE100
    2005 Yamaha TW200
    2007 Yamaha TW200
    2007 Kawasaki Vulcan 500
    2008 Honda Shadow 750
    2009 Honda Rebel 250
    (current)2008 Harley Sportster 1200 Custom
    Member Jon H's Avatar
    Oct 2011
    Aurora, CO
    85
    Thanks for taking the time. I'm also tempted by the shiny new pipe, but then I have to consider the needs of my other bikes...
    1987 TW200
    2000 Yamaha XT350
    2005 Yamaha Majesty
    2009 Honda Ruckus
    Member timberfalls's Avatar
    Nov 2010
    The Wet Coast
    65
    Hi Krossroads I'm already looking into importing one of those DG pipes; did you get the silencer as well? are you going to stick with the stock 128 jet? Looking forward to hear about the speed test and what adjustments you make. Any rumors of a video of the final product?! hahaaha ttyl Timber
    Most motorcycle problems are caused by the nut that connects the handlebars to the saddle
  1. Old airbox boot.. new airbox boot.. still too short
    By silverhead in forum Technical Help
    Last Post: 05-10-2013, 12:36 AM
  2. FMF pipe/stock header for sale
    By bruisr in forum TW200 Classifieds
    Last Post: 04-15-2013, 09:56 AM
  3. Stock jetting at 9000 feet?
    By DonBenito in forum Technical Help
    Last Post: 07-25-2012, 09:26 PM
  4. jetting complete for dg pipe
    Last Post: 03-27-2012, 08:54 PM
  5. Stock Pipe
    Last Post: 04-13-2011, 02:55 PM
1972 yamaha r5c dg pipes stock air box need to jet carbs
dg dr200 exhaust
dg exhaust yamaha tw200
dg o series jet kit dr200
jetting with dg exhaust
main jets for a 1996 yamaha tw200 with a dg-o series exhaust
rejeting xt350
tw200 exhaust jetting
tw200 jetting
tw200 rejetting for pipe
yamaha r5c jetting
yamaha r5c pipes
