jetting complete for dg pipe
Results 1 to 3 of 3
    Senior Member dganey's Avatar
    Oct 2010
    SE Michigan
    341
    To any and all who -like me- read all the reports of rejetting and happy cutomers, +1 for me! Even after reading the all the good reports, I was still happily surprised with the results. The quick start-up, takes throttle right away, mid-surge gone, and throttle response improved. Heck, 1st gear is even usable now. Although, I can easily start in 2nd gear now smoothly. Like others have said, it feels like an extra 50cc or so. It has been said many times, but deserves repeating--just do it, rejet!. I installed an OEM yamha 130 main with five .01 mcmaster carr shimms under the needle. 2.5 turns out on the pilot screw. Installed a new bowl gasket and four m4 x 16mm bolts with 4mm lock washers. I have the dg oval series exhaust with quiet core insert. 1st time jetting for me. I did break the 1st main jet off in the main nozzle due to overtightening. I originally left the carb in place and rotated it to work on it. After breaking the jet, I removed the carb to better judge the amount of force for tightening. In summary, if I can do it, you can do it--thanks to all of the others before us!
    Dusty
    Jun 2011
    Dothan, AL
    1,715
    Satisfying isn't it. I just did mine as well. I also had to replace the float valve needle and seat, the o-ring was shot. Plus you can clean the whole thing really well taking it off and it doesn't really take any longer to do it right the first time.
    2005 TW200 (SOLD)
    2013 DR650
    Junior Member dirkK's Avatar
    Mar 2012
    3
    Awesome. I can't wait to try it.
  1. Looking for a complete wheel set
    By Woodi23 in forum TW200 Classifieds
    Last Post: 02-08-2013, 10:39 AM
  2. Jetting for maintenance
    By Adam-n-nevada in forum Technical Help
    Last Post: 11-02-2012, 07:53 PM
  3. "my" jetting with DG pipe and stock airbox
    By Kirk Ross in forum Performance and Customization
    Last Post: 03-13-2012, 09:50 PM
  4. What do I need to complete this carb?
    By BBMS in forum Technical Help
    Last Post: 07-23-2011, 12:46 PM
  5. Complete Teardown
    By assquatch20 in forum Technical Help
    Last Post: 09-11-2010, 04:11 PM
2013 tw200 jetting
dg exhaust jetting
jetting
stock pipe jetting tw 200
tw jetting for pipe
tw200 dg pipe jetting
tw200 dg pipe rejet
tw200 rejetting for pipe
