Hollow Mod... Battery holder question
Results 1 to 4 of 4
    Junior Member workinprogress's Avatar
    Sep 2010
    6
    I've started out on a hollow mod for my 07 TW. I removed the airbox and put in the aftermarket(k&n) filters, and so as expected I now have an empty hole where the battery belongs. So now my question, are there any simple ways to create something to hold the (stock) battery in place? I've heard of using sheet metal, but for some reason my local hardware stores don't carry any. I'll probably end up taking a trip to Lowe's, but in the meantime I'd like for the bike to at least be rideable. Would it be possible to cut out the stock battery holder from the stock airbox and mount that? Right now I'm stuck using an old skateboaring knee-pad fastened by velcro and zip-ties, it does the trick and holds well but I wouldn't risk bringing it out on the road.
    Heres a couple pics of the bike so far, still a lot of work to be done.
    Junior Member Snaggletooth's Avatar
    Sep 2010
    4
    A biscuit tin if you can find one the right size but you really wanna build a sheet metal one if you wanna keep your stock battery.
    Have you considered a gel battery which is a lot slimmer & can be placed on its side in your under seat tray? Much neater.
    Senior Member catamount's Avatar
    Aug 2010
    Vermont, USA
    323
    Quote Originally Posted by workinprogress View Post
    Yes. On the 'old' forum there was a guy who trimmed down his stock battery box and used that.
    Ah ha... after some searching, I found it!
    His build is documented on this link:
    Next step was the battery holder/standard air box.
    i didnt want that big and bulky box and air filter unit to spoil the bike, so i trimed it all down, and just left enough of it to suport the battery.
    we replaced the standard air filter with a small one, and hid all the wireing up under the seat.
    This is how it looked before.
    triming it down, and fileing down all the edges...
    Of course, that will still hang down a ways into the "hollow":
    Check out my custom TW200 build Hidden Content .
    TTR225 SS header, FMF Turbine Core 2 pipe, EK o-ring chain, 15T front sprocket, 50T rear sprocket, 20W fork oil, Drag Specialities speedometer, Victory Vegas headlight, Acerbis universal supermoto front fender, Vintage Yamaha chrome gas cap, Integrated LED rear tail/turn/brake light, Yamaha Blaster shock, Pro Taper SE ATV High handlebar, Western Powersports off-road handguards, Pro Taper Pillow Top Lite grips, Over-sized foot pegs, Maxxis 6006 front tire, seat cover from eBay seller mac32756.
    4 lithium ions in a flat-4 arrangement will fit under the seat at the top of the stock battery location and not even show.
  1. bunjie hook holder
    By r80rt in forum Performance and Customization
    Last Post: 06-17-2013, 07:20 PM
  2. Trail map software and GPS holder
    By mpilla in forum Trails, Off-road, and Adventure Riding
    Last Post: 10-13-2012, 11:00 AM
  3. fishing rod holder
    By howardgene63 in forum Performance and Customization
    Last Post: 03-28-2012, 12:32 PM
  4. Battery question
    By kj7687 in forum General Discussion
    Last Post: 01-23-2012, 06:37 PM
  5. factory cup holder
    By cipe in forum Performance and Customization
    Last Post: 04-25-2011, 02:40 PM
replacement airbox tw200
tw200 air box
tw200 battery box
tw200 battery box dimensions
tw200 custom battery box
tw200 hollow body battery
tw200 hollow mod
tw200 hollow mod battery holder
tw200 mods
yamaha tw battery box
yamaha tw battery bracket dimension
yamaha wt 200 battery
