TTR clutch conversion
Results 1 to 7 of 7
    Jul 2011
    1,123
    I need a new "clutch boss" but nobody can get one as they are on backorder from yamaha for at least a month supposedly...
    Ronnydog used TTR clutch on his big motor build... Can I just buy the clutch cover and clutch assembly from a TTR (which one? 125? 225? 230? 250? any?) and bolt it right on?
    It looks like there are TTR125 clutch covers and clutches on ebay for ~$40 each, so if I could do the whole swap for $80+shipping that would be way cooler than not being able to get the tw200 part forever
    ITCB
    Jul 2011
    1,123
    Ehhhhh it is the TTR125 parts that are cheap on ebay.. Don't even see any covers for sale for the 225 and it looks like that is what Ronnydog was using.
    ITCB
    Germany, Werdau
    1,014
    Info:
    The TTR125 clutch cover will not fit on the TW engine.
    The covers from the bigger TT/XT engines (max. 230ccm) will fit.
    Poway CA.
    2,099
    Quote Originally Posted by operose View Post
    Operose, the shaft spline on the left is the TTR and on the right is the TW. I used the TTR shaft with the 6 speed. I do not know if there are dif years with dif shaft splines or if the XT225 will work. Clutch cover I used is the TTR and it fits.
    Ronnydog
    Jul 2011
    1,123
    Thanks Ronny. I've probably dug too deep into the wallet for the bike already this year, so this probably won't happen. Trying to work a deal with mac for a used clutch boss he has in stock.
    This should be very useful info for anyone else thinking about the conversion though!
    ITCB
    Poway CA.
    2,099
    PM me I my have a extra one.
    Ronnydog
    Senior Member christddel's Avatar
    Oct 2010
    Belgium
    376
    Attention,
    it is probably necessary to change the pinions of transmission.
    The ratio is 73-22 or 74-20.
    Is then necessary to disassembling…To keep that d' origin. change 5 disc Clutch, to 6 disc with 6 shock absorber (made Christddel )
  1. Clutch Engagement vs Free play in clutch lever
    By Jay-2 in forum Technical Help
    Last Post: 04-09-2014, 06:24 AM
  2. cdi conversion for 87?
    By esw28 in forum Technical Help
    Last Post: 03-26-2013, 09:21 AM
  3. 125 conversion to 200
    By gardar in forum Technical Help
    Last Post: 10-11-2012, 04:42 PM
  4. K&N filter conversion?
    By adavis in forum Performance and Customization
    Last Post: 10-09-2012, 08:02 PM
  5. tw200 automatic clutch conversion
    By brharris27317 in forum Technical Help
    Last Post: 10-15-2010, 10:42 AM
225 clutch install
clutch kit
