The Dub gets a meter
Results 1 to 9 of 9
Like Tree14Likes
  • 8 Post By jtstdub
  • 6 Post By SportsterDoc
Thread: The Dub gets a meter
    Jan 2015
    Fair Oaks, Calif
    500
    Well I hate not knowing what my charge systems are doing in everything that I own... I finally ordered some nice little meters and got one installed in my Dub and also one in my Scoot...
    Got a bunch of these:
    I tested them and they will display and read down to 4 vdc, that is as low as my bench PS works...
    I did test to see if I could run them continuous but the current draw is a bit too high... 14.x ma would suck the juice out of the battery in a couple of months. 1000 hrs= 42 days... = 14 amp hours removed from the battery.
    Click on images to see bigger picture.
    New DC 12V-24V Car Motorcycle LED Panel Digital Display Volt Voltage Gauge Meter | eBay
    Jim
    Mattwings, scotti158, Ken and 5 others like this.
    Jan 2017
    Southern Nevada
    1,077
    I very much appreciate gauges!
    Did you wire it through the keyed switch?
    How readable in the sunshine?
    Back in 76, I used a zener diode with a threshold voltage of 13.8, in series with an indicator lamp.
    It would not show an overcharge, but illuminated when voltage was 13.8 VDC and +.
    2014 Honda CB1100
    2018 Yamaha XT250
    2016 Moto Guzzi V7 II
    2017 Yamaha TW200
    2012 Triumph Bonneville
    2002 H-D Sportster 1200 Sport
    2003 H-D Sportster 883
    1976 Honda CB750F
    1975 Honda CB360
    1970 Yamaha CT1
    1972 Yamaha CT2
    1972 Yamaha AT2/CT2
    1970 Honda SL350
    1970 Honda CL350
    1967 Honda CL160
    1967 Honda CB160
    1962 Honda CA110
    Junior Member sprocket42's Avatar
    Feb 2017
    Wexford, Ireland
    22
    Hey JTSTDUB where did you get that fancy speedo/tacho was it an easy fit, and also was it expensive. Thanks
    Nov 2010
    Frostbite Falls Ill
    2,719
    Just mount it wired in series to a small toggle switch to turn it off when not riding. That will prevent power loss when it is parked.
    Phelonius
    Jan 2015
    Fair Oaks, Calif
    500
    Quote Originally Posted by phelonius View Post
    That could be done but just one more thing to mount somewhere... I just wired into the switched output of the ignition switch. I used a .5 amp pico fuse for protection.
    Jim
    Jan 2015
    Fair Oaks, Calif
    500
    Quote Originally Posted by SportsterDoc View Post
    The led display seems to be just fine. I did mount it down n the shadow area of the Jimbo shield.
    Yes, I taped into the switched power output from the key switch. Protected with a .5 amp pico fuse.
    I have been in the electronics world for 50+ years.
    Jim
    Jan 2015
    Fair Oaks, Calif
    500
    Quote Originally Posted by sprocket42 View Post
    The display is a Trail Tech...
    this one.
    https://www.amazon.com/Trail-Tech-75...WFVPF2AMPGKR7Q
    I did have to fabricate a mount to put it where I wanted it...
    The wiring to make all the functions work is laborious and requires a need for detail. At least that is my thoughts. One could hack it in but I think one might end up with an intermittent POS.
    Here is ROBG's Trail Tech install. My fabricated mount was quite a bit simpler than his. Like he said, " I was bummed, but I guess not really surprised, when the "TW-Specific" version of the Vapor didn't include a specific mount. Instead I just got a very weird speedo cable that I have to build a bracket for."
    https://tw200forum.com/forum/performa...ash-vapor.html
    Jim
    Jan 2015
    Fair Oaks, Calif
    500
    Oh wow, I was reviewing RobG's trail tech Vapor install for another thread and noticed I did not respond to your question about the meter display in sunlight... Well it sucked... One of these days I will switch to green or blue. They are very cheap.
    Jim
    Jan 2017
    Southern Nevada
    1,077
    Quote Originally Posted by jtstdub View Post
    Thanks, Jim.
    That is the challenge for many digital displays.
    OTOH, my CB1100 is very easy to read in bright sunlight, but with very dark goggles and when blocked by the flyscreen, it is a strain to read trip meter/MPG/fuel consumption.
    2014 Honda CB1100
    2018 Yamaha XT250
    2017 Yamaha TW200
    1976 Honda CB750F
    1975 Honda CB360
    1970 Yamaha CT1
    1972 Yamaha CT2
    1972 Yamaha AT2/CT2
    1970 Honda SL350
    1970 Honda CL350
    1967 Honda CL160
    1967 Honda CB160
    1962 Honda CA110
  1. Control and meter cable?
    By Howdy in forum Technical Help
    Last Post: 10-29-2015, 06:40 PM
  2. Trip meter knob
    By lizrdbrth in forum Technical Help
    Last Post: 05-02-2013, 09:30 PM
  3. tach/ hr meter cheap
    By Stromper in forum Performance and Customization
    Last Post: 03-31-2013, 07:30 PM
  4. Trip meter
    By Drifter in forum Technical Help
    Last Post: 09-07-2012, 04:31 PM
  5. WTB....Meter Bracket
    By dbreinich in forum TW200 Classifieds
    Last Post: 03-01-2011, 09:12 AM
