Sprocket Suggestions
Results 1 to 10 of 15
Like Tree37Likes
Thread: Sprocket Suggestions
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    1,932
    I would like to know, what are your favorite brand rear sprockets? I don't remember if I ever changed my rear sprocket or not. I only change what is bad unless there is significant wear on any of the other components. So far with 43000 miles, 2 front sprockets, 3 chains, rear sprocket 1 or 2 but I don't think I ever changed the rear. I may go ahead and change both sprockets this time, my o ring chain is not that old. The chain trick is to get the highest tensile strength you can find in the size that fits your bike. I found a chain that will handle 1000cc and I put that chain on my 600. No chain adjustment many miles later, works great.
    admiral and cowboyjeff like this.
    Senior Member UncleRandy's Avatar
    Feb 2015
    Alaska
    165
    I guess I'll go first. I have faithfully used SunStar brand steel sprockets on all of my motorcycles since I began riding. They are durable, economical, and perform like a sprocket should. I've used both front and rear with the same results.
    littletommy, admiral, Ken and 2 others like this.
    Frosty Hollow
    13,094
    Quote Originally Posted by Ken View Post
    I would like to know, what are your favorite brand rear sprockets? I don't remember if I ever changed my rear sprocket or not. I only change what is bad unless there is significant wear on any of the other components. So far with 43000 miles, 2 front sprockets, 3 chains,rear sprocket 1 or 2 but I don't think I ever changed the rear. I may go ahead and change both sprockets this time, my o ring chain is not that old. The chain trick is to get the highest tensile strength you can find in the size that fits your bike. I found a chain that will handle 1000cc and I put that chain on my 600. No chain adjustment many miles later, works great.
    First, let me say if you got 43,000 out of a sprocket I am extremely impressed. I'm a little confused as the highlighted portion has me a little confused. You mention your on your 1st or 2nd rear sprocket but then never changed the rear. Either way, 1 or 2 sprockets thats still very impressive. I change mine about every year though I do have a lot of sand, dirt and other misc. debris grinding between my chain and sprockets.
    Anyway, I can't really say which one is best but I can tell you which one's I've used. Like UncleRandy I've used a SunStar, OEM, JT Sprocket, and recently I special ordered a 60T from Sprocket Specialist.
    If your sprocket looks like this (below), then you are way overdue. I had some chain skipping over the teeth on steep downhills. I didn't know this was the problem at first but I learned from experience what it was. Nowadays I'm sensitive to worn sprockets and can tell fairly quickly.
    I think this was one of my used SunStar sprockets.
    Can't remember the one below which was worn but I think a JT but could be another SunStar
    elime and Ken like this.
    6,985
    I like steel sprockets. I don't know why because I have never tried anything else. They just seem better than aluminum.
    I replaced the front and rear sprocket and chain over 30,000 miles ago. The front sprocket teeth are very worn but are standing straight up and down -- no tsunami effect -- which I understand is caused by a stretched chain. My chain is still within operating limits in terms of stretch. The chain has been taken care of fanatically. Next time I will try an O or X ring chain to see if it lasts as long.
    Right now I am tortured with the task of making a decision whether to replace the front sprocket, the front sprocket and chain, or the front and rear sprocket and chain. I hate not maximizing the use I can get out of something. I have new sprockets and chains and gaskets and seals all sitting on the shelf ready to be used.
    admiral, LuvNot, Ken and 1 others like this.
    Pleasanton, CA
    5,747
    I say just replace the front sprocket and see if you can get another 10,000 miles out of the current chain and rear sprocket.
    Hailey, ID
    3,377
    I like JT sprockets. If your front sprocket looks like the one on the left in Admiral's photo, replace it. If you rear sprocket looks like the one on the left in Admiral's photo, replace it. If BOTH of them look like Admiral's, it is probably a good idea to replace the chain too. I did just what TW Brian suggested, but my O-ring chain only had about 6,000 miles at the time. The rear sprocket is still fine 5,000 miles later, or 12,000 total
    Ken likes this.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Aug 2016
    Houston, Texas
    1,932
    I did write that kind of confusing. I don't remember ever changing the rear sprocket. If it was ever changed it was probably only once. I think I am with the majority here with the steel sprockets. I think I am going to change both sprockets at this time. I may have changed the front one only once. I have the original front sprocket still here that the chain spun around it. The rear at this time is much worse than Admiral's pic. I parked in just the right spot at work and saw something shiny on the rear sprocket, broken teeth. Thanks for all the suggestions. I am going to shop around. I'll update with my choice after the change.
    admiral and littletommy like this.
    Aug 2016
    Houston, Texas
    1,932
    One more question about the sprockets. My experience is the front wears out at least 2 front sprockets to one rear. Has anyone had any front sprockets that have lasted the life of the rear, and how many miles?
    cowboyjeff likes this.
    Senior Member methamphetasaur's Avatar
    Jun 2015
    Colorado
    1,166
    I don't know man, I haven't ridden the TW far enough yet to wear out either [<6k miles on the current non stock size ones], but on everything else the rear has worn out well before the front sprocket.
    Senior Member LuvNot's Avatar
    May 2015
    Hampton, VA
    927
    Need some education about sprockets. I looked up the JT sprockets on Amazon, then realized I had no idea how to specify what kind of hub I'll need.
    I know we need the smaller hub size. But there's a bunch of sprockets that look the same on the page, but have different model numbers.
    I looked up the OEM part hoping to find something that would help, but the only numbers provided are stock numbers.
    Any guidance here would be greatly appreciated.
    littletommy likes this.
    My 2-Wheel Babies: 2017 Versys X 300 - 2006 Kawasaki Nomad 1600 - 2009 Piaggio MP3 500 - 2014 Honda Ruckus
  1. Any suggestions?
    By Adventerious Dutchman in forum Performance and Customization
    Last Post: 05-25-2017, 12:31 AM
  2. Replies: 0
    Last Post: 02-23-2017, 04:59 PM
  3. Battery Suggestions..
    By dwil4 in forum General Discussion
    Last Post: 01-20-2017, 06:06 AM
  4. New tire suggestions
    By STW_TW200 in forum General Discussion
    Last Post: 07-05-2015, 06:38 AM
  5. Replies: 0
