Raised fender w/ springs
Results 1 to 10 of 14
    Aug 2011
    Cayce, SC
    3,109
    I saw someone that spoke about raising the front fender an inch or so I went ahead and did it for about $5. There were no pictures of it so I went ahead and tried it using longer bolts and compression springs. I figured the spring would be best for when I drop it so it has a little play.
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    Tennessee
    1,285
    Looks neat. I wish someone was out there making a fork brace though for the flex from twisting.
    Senior Member greendub's Avatar
    Montgomery, VT
    220
    Does it hit the top if shock is bottomed out?
    Aug 2011
    Cayce, SC
    3,109
    No. If I raised it another inch or so it would but then it would also rub the boots when they compress. The way it sits now is perfect!
    Senior Member r80rt's Avatar
    Sep 2011
    2,431
    It looks great, good idea.
    Aug 2011
    Cayce, SC
    3,109
    I took it out to do a little more "testing" and felt it tap when completely compressing the forks so i'm going to cut down the bolts a 1/4 inch or so until the problem subsides.
    Montgomery, VT
    220
    Noticed when I chenged my fork oil that mine is abot 1/16" below the top. That is with oil drained. I have a 3/16" spacer. So sounds like a 3/4" will work. perfect! thanks
    Apr 2011
    Martinsville Indiana
    2,089
    I did about the same thing but used 6-8 washers and longer bolts but only raised it about 1/2 -5/8 inch. Looks good and keeps your tire from locking up in the muck.
    Senior Member joedirt1970's Avatar
    Cardiff by the Sea, CA
    1,345
    Can we get a pic from a little farther back to get a better perspective?
    Hidden Content [/IMG]It's not why, but why not. Do it for the right reason now, versus the wrong reason later.
    Born on a Honda Z50, '78 YZ 80, '79 Husky WR 250
    2008 TDub--Jimbo Shield, Lizard Oil Cooler, Blaster Shock, YZ Hybrid Forks, Supermoto front fender, ATV Bars, Acerbis Brake Cover, 1460 Pelican Case, Cycle Rack, Power Core, Gold Chain.
    Aug 2011
    Cayce, SC
    3,109
    Quote Originally Posted by Brock View Post
    I'll take one tomorrow when I get it adjusted to where it doesnt hit the tripletrees when bottoming out. I cut the bolts down 1/4 inch and it still taps when I bottom out the forks. I'm trying to get it as high as possible without any contact. Now its at around 11/16in. Will have to snip the springs and cut the bolts again tomorrow.
  1. Replies: 4
    Last Post: 05-30-2013, 08:56 AM
  2. Tiddie Springs II - The Movie
    By admiral in forum Trails, Off-road, and Adventure Riding
    Last Post: 04-25-2013, 04:47 PM
  3. raised front fender
    By joeband in forum Performance and Customization
    Last Post: 06-28-2012, 09:09 AM
  4. Front Mudguard raised.
    By Grant in forum Performance and Customization
    Last Post: 05-20-2012, 06:10 PM
  5. Fun near Colorado Springs.
    By CS1983 in forum Trails, Off-road, and Adventure Riding
    Last Post: 09-13-2011, 03:37 PM
front fender
