A FEW QUESTIONS
Results 1 to 4 of 4
Thread: A FEW QUESTIONS
    Junior Member HUBJ53's Avatar
    May 2012
    1
    I just bought a 2001 TW 200 and have a few questions on it. I have read about every post on here I can find on the carbs and jetting and am unsure on why my bike would have a #120 jet in it. I am pretty sure no one has been into the carb before me. Everything I have read on here says they came with a #125 jet from the factory. Are the factory jets hex shaped? I ordered a #128 from my Yamaha dealer, a yamaha jet and it is a hex. I also ordered the ajustable needle. 2001 seems to be the crossover year, so I would not have the early carb, would I?, meaning the small jet #s.
    Also no-one on here mentions anything about the tiny spring that sits on top of the needle and goes shooting into outerspace when you pop the needle out of the diaprham - fyi.
    What are the correct valve lash specs please? I don't want to download the service manual at work.
    Thanks
    Ephrata, WA
    1,125
    Intake: 0.05-0.09 mm (0.002-0.004 inches)
    Exhaust: 0.11-0.15 mm (0.004-0.006 inches)
    1990 TW200
    Senior Member FortPayne's Avatar
    Nov 2011
    Alabama
    326
    Im at almost 3,000 miles and decided to do my valves yesterday. Got everything apart only to find they were within spec and needed nothing. Guess I'll check again in a another few thousand.
    Tenaciously Deviant Unwittingly Brilliant
    Member BuddyMc's Avatar
    Huntsville, AL
    99
    Quote Originally Posted by Fort Payne View Post
    I'm about to catch you mileage-wise with my 09! You can practice setting the valves on mine if I can ever get you over here to ride! Looking forward to it!
    A figure eight route would be a nice ride around Talladega NF. If we start at Piedmont (heading south <on 500?> and west) and ending near Sylacauga, then north up the Skyway, swing around Cheaha to head east toward Lineville. From there, we can head back to Piedmont. My guess is that is a 75 - 85 mile run / maybe 4 hours of saddle time.
    We should invite Boedy, Twisty, Driver, Joel, BuddyMc, and you so we have a good size group to "thunder through the forest".
    Huntsville, Alabama - Have TW, Will Ride! All White 09 TW, D2Moto Pegs, Bridgestone 302 front tire, 2" higher bars, 3/4" fork preload spacer, 5wt Honda fork oil, 135mm fork oil level, exhaust tip mod, 2.5 turns out fuel mixture, 0.060 in needle shims, 130 main jet, 14/47 sprockets, 20w-50 Valvoline MC full synthetic oil, ImmixRacing rear rack, Bilt Bag on Rack, 1" front fender spacers, Battery Tender connections on new battery (installed 12/11), Coleman ATV seat cushion, 2 Agri Supply tool tubes, 30oz MSR Fuel Bottle, auxiliary 6 LED tail light, Sylvania Silverstar Ultra H4 headlight bulb, 2357 turn signals, and Superbright's 1157 LED Motorcycle Tail Light Bulb with 19 red & 6 white LEDs. Shortened rear turn signals. Bypassed kickstand switch.
    Plus a "new to me" 1995 Yamaha Virago XV 750G for Pavement Purposes!!
  1. A few questions
    By nfpgasmask in forum General Discussion
    Last Post: 12-10-2012, 01:30 PM
  2. Hi, new here and a few questions about the tw
    By Alanyuen680 in forum General Discussion
    Last Post: 06-06-2012, 06:19 PM
  3. A few questions.
    By Revolverman in forum General Discussion
    Last Post: 05-22-2012, 10:52 PM
  4. Few questions
    By mjlater in forum Performance and Customization
    Last Post: 02-21-2012, 03:01 PM
  5. Questions
    By shaneatalki in forum General Discussion
    Last Post: 04-24-2011, 03:55 PM
