Clutch springs with Max clamping pressure...
Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Like Tree26Likes
Thread: Clutch springs with Max clamping pressure...
    Senior Member drstimpy's Avatar
    Oct 2013
    Rochester, MA
    238
    Guess the title says it all. I'm not worried about lever pressure, I'm just tired of any slipping. The Barnett springs I got with my plates aren't strong enough. Need the most bad ass ones out there!
    Thanks
    Some must watch while others must sleep.
    2013 TW 200
    2014 NC700x
    2016 k1600gt
    2016 TW 200
    18,578
    No matter what springs one uses one can also add washers to preload the clutch springs a bit for greater engagement pressures.
    You’ll have firmer clutch lever effort. So if you want equal sized PopEye arms practice a lot of “Stoppies” to build up the right arm to match the clutch arm. 11205873_414815475359675_98962203_n.jpg
    drstimpy and cowboyjeff like this.
    Oct 2013
    Rochester, MA
    238
    You wouldn't happen to have a size on the washers would you?
    cowboyjeff likes this.
    2013 TW 200
    2014 NC700x
    2016 k1600gt
    2016 TW 200
    6,956
    Washers do increase the pressure on the discs but you really can't feel it in the clutch lever.
    Oct 2013
    Rochester, MA
    238
    Size and material of washer...anyone?
    Or a place to get some springs that are firmer than the barnett ones?
    Thanks
    2013 TW 200
    2014 NC700x
    2016 k1600gt
    2016 TW 200
    6,956
    I looked for the washers I had and can't find them. I guess I put them back into the clutch when I installed the Barnett. I do remember they were iron but brass I am sure would work OK.
    As for size, what I did was carefully measure what I needed and then went to the hardware store. There I found the closest washer I could to my measurements. When I got home I then had to file them to fit. A little bit off the outsider and more than a little bit off the inside. Procedure was repeated at one of TW-Brian's Wrench and Rides for some other TW riders. No big deal. Not hard to do. Doesn't even take much time. Well worth the effort.
    I hope this helps.
    Oct 2013
    Rochester, MA
    238
    Yes I would love to just get the correct springs!
    2013 TW 200
    2014 NC700x
    2016 k1600gt
    2016 TW 200
    6,956
    Ronnydog says he had to make his own washers too.
    https://tw200forum.com/forum/technica...all-gears.html
    Pleasanton, CA
    5,681
    I tried unsuccessfully to find some off-the-shelf washers that would work. I even went as far requesting a quote for getting some washers custom made so I could offer them to forum members that were looking for some. Unfortunately, the cost was a little higher than I had hoped for.
    See the attached quote for the size that I had determined was needed.
    6,956
    Fifty cents a piece isn't bad if you can buy only 4 of them only then they won't be called washers but something like "clutch springs enhancement shims". Heck, "clutch spring enhancement shim" should be worth a buck each plus S&H!
    cowboyjeff, TW-Brian and ejfranz like this.
  1. Starter motor brushes - Springs or no springs?
    By Hidebound in forum Technical Help
    Last Post: 08-09-2016, 10:17 PM
  2. Clutch levers and springs
    By BRug14468 in forum Performance and Customization
    Last Post: 03-07-2015, 12:34 AM
  3. 141.1 Max
    By scotti158 in forum General Discussion
    Last Post: 08-14-2014, 05:51 PM
  4. Tubes leak at low pressure but not high pressure?!?!
    By misterb in forum Technical Help
    Last Post: 07-07-2013, 10:42 AM
  5. max. speed
    By mcbabel in forum Technical Help
    Last Post: 11-08-2010, 08:22 PM
