Banshee stock question
Results 1 to 8 of 8
Like Tree13Likes
  • 1 Post By Toecutter
  • 1 Post By Tiny-Wheel-200
  • 2 Post By Tiny-Wheel-200
  • 2 Post By ronnydog
  • 4 Post By ronnydog
Thread: Banshee stock question
    Senior Member Toecutter's Avatar
    Sep 2016
    North Idaho
    283
    So after reading all that i can on shocks (i think), i cruised on over to ebay to see how much a banshee shock would be. Seems like $100-$200 Is the going rate depending on wear. I also noticed there are some new chinese replacements that look pretty sweet for cheap money. Any experience with these?
    Thanks in advance.
    littletommy likes this.
    Senior Member Tiny-Wheel-200's Avatar
    May 2013
    Wasilla, Alaska
    720
    The most important thing with a banished shock is that you absolutely need a heavier custom spring for it. I ran a stock spring and would bottom out rubbing the tire on the plastic about 200 times in a normal ride. Its about 120 dollars from racetech. Get the heaviest one they offer. Don't waste money on a Chinese shock when you're going to needs an American spring!
    Sent from my LGL63BL using Tapatalk
    Sep 2016
    North Idaho
    283
    Thanks for the input! One of the things i had read was the the stock spring would work with a spacer. Id assume cause it would add some preload. Im about 190 without any gear on, which stiffness did you get?
    Thanks
    May 2013
    Wasilla, Alaska
    720
    I can't remember the weightbit it was the heaviest one they make. I tried forloading the banished spring bjt it was not even close. I'm same wdighf as you and just sitting on the bike would use like 80 percent of the travel
    Toecutter and littletommy like this.
    Sep 2016
    North Idaho
    283
    Ok, thanks. That would be a big disappointment for sure.
    Poway CA.
    2,099
    I made a spacer and I'm still using the stock spring. IMG_0796.JPGI can rebuild your shock and lower it at the same time so your bike doesn't look like a stink bug!
    ronnydog
    littletommy and Toecutter like this.
    Poway CA.
    2,099
    The shock is performing excellent, super improvement over stock.
    ronnydog
    Sep 2016
    North Idaho
    283
    Hopefully ill be in a position to take u up on that soon. Thanks
  1. Banshee Shock Question
    By Skyking in forum Technical Help
    Last Post: 09-04-2014, 08:27 AM
  2. New Old Stock pricing question
    By Bosshoff in forum General Discussion
    Last Post: 01-03-2014, 09:34 AM
  3. Stock muffler question
    By Adam38654 in forum Technical Help
    Last Post: 07-11-2012, 07:46 PM
  4. Banshee Handlebars
    By Kirk Ross in forum Performance and Customization
    Last Post: 02-28-2012, 06:17 AM
